it looks like the spare is .018 to .035 and the one on the tool
is thicker, like .040-.050 etc.
years ago I had used one, and they are very accurate, once you get
used to using it, you would like it.
patent number 2,645,142 was issued to Otto Schwenzfeier, McCook, Nesbraska on July 14, 1953
if you put the patent number in DATAMP, they do not show it, but will lead you to the patent
by clicking on the line that show USPTO information.
the patent shows the tool with a spark plug set into it. the write-up really explains the use.
remember when you used the old tool that lifted the stem that you set the gap, and sometimes
it would twist as you were prying it up, this tool prevents that from happening.
