Author Topic: #14 wrench?  (Read 1999 times)
#14 wrench?
« on: June 27, 2016, 01:25:18 PM »
It says 14 on it now I'm no metric expert but 14mm is about 5/8"  that is the next size down from 11/16ths in most wrench sets. The Barcola is one I found hiding which #14 the other hiding were rusty so they are having a mollasses  bath for a week or two.
So is #14 part of a set? it may have more info under the tar like crap that doesn't want to come off!
Re: #14 wrench?
« Reply #1 on: June 27, 2016, 01:34:22 PM »
if its tar, soak it in kerosene.
Re: #14 wrench?
« Reply #2 on: June 27, 2016, 02:35:18 PM »
I would but don't have any, not sure how well old gas would work? not sure where my bucket of old diesel is?
  • Administrator
Re: #14 wrench?
« Reply #3 on: June 27, 2016, 02:42:11 PM »
14 mm is closer to 9/16", close enough to interchange often.
Re: #14 wrench?
« Reply #4 on: June 27, 2016, 03:46:31 PM »
I really like those Convex open enders.
Re: #14 wrench?
« Reply #5 on: June 27, 2016, 04:34:06 PM »
2 more wrenches popped up when I moved a small pc of sheet metal??? how long they have been there? weird!
on is plain no name 3/4" combo. then there is this one.
"keystone"  and a L in it?  something like?  from Lancaster, Pa. ?
  • Administrator
Re: #14 wrench?
« Reply #6 on: June 27, 2016, 05:15:27 PM »
"L" in a keystone logo
Lakeview /Lakeside Forge of Erie, Penn.
Source: Lakeview Forge company history and several old periodial advertisments.
The Lakeview Forge Co. succeeded the Lakeside Drop Forge Co. in 1925. Erie Tool Works is another division of the same corporation
Several wrenches seen with this logo including one marked "M. H. T. Co."
Thanks to The Wrenching News
Offline tool fool
Re: #14 wrench?
« Reply #7 on: July 01, 2016, 10:03:39 PM »
The tar like crap is probably cosmoline, used for preserving steel parts,tools, and other steel items, usually applied right after manufacture, so it has a good chance of being in excellent condition. Kerosene or any Stoddard solvent will remove the cosmoline, but it may take a little scrubbing with a rag. Don't use a scotch brite pad as it will scratch any plating that has been applied to the wrench. Also, never use any gasoline to clean anything as it is very dangerous and can also damage the finish. Plus there are better cleaners out there anyway. Good luck.
