Author Topic: What is it? Gripper? Puller?  (Read 1516 times)
Offline patack
« on: April 25, 2017, 05:22:40 AM »
Hello,
I seem to have a fascination with tools that I can't identify.  Could be more of an addiction lol
This is what I know:  Nothing
This is what I think:
Puller or gripper for an older car or truck
Adjustable.  Once gripped, locks in place.
Measures 10"
No mfg found
Number incised in a border: 61-2556
Any idea what it is and/or who made it?  How old?
Thanks.
Re: What is it? Gripper? Puller?
« Reply #1 on: April 25, 2017, 06:00:20 AM »
Valve spring compressor?
Offline patack
« Reply #2 on: April 25, 2017, 06:41:22 AM »
No question mark needed, Mark.  That was quick.
So, it is antique.  I haven't found or matched the exact number, but found a listing for Model T/A by Endestro.
I think they mean Indestro which began in the late 20's which would make it a tool for a Model A?
Now, to see if I can find the model number.
Thanks so much.  Appreciate any additional info.
« Reply #3 on: April 25, 2017, 09:51:38 AM »
Valve spring compressor, yes - although I've seen them called "lifters," too - for a flathead/side valve engine.
Offline patack
« Reply #4 on: April 25, 2017, 10:11:05 AM »
Thanks, Bill, more great information.
So, have we agreed it is for a Model A?
Offline patack
« Reply #5 on: April 25, 2017, 10:24:10 AM »
Forgot to mention that I can't confirm or deny that this is made by Indestro
« Reply #6 on: April 25, 2017, 12:16:24 PM »
That valve spring compressor could be used for many different flathead / side valve engines. It will not work on Ford Flathead V8's tho. I have used that type of tool many times working on older model forklifts using Chrysler 251 and 264 CI six cylinder engines.
« Reply #7 on: April 25, 2017, 08:25:55 PM »
 a valve lifter opens when the handles are squeezed.
 a valve compressor will close when the handles are squeezed.
 I believe ?
« Reply #8 on: April 25, 2017, 09:12:31 PM »
 I believe ?
A useful way to think about it.
A lot of the valve (spring) compressors for overhead valve motors look like huge lightweight C-clamps with a ratchet or screw to compress the spring.  The head's off the motor when you're doing this, so you can fit the big C-clamp around the head.
With a flathead motor, you often do valve work without removing the intake/exhaust manifold, carb, etc.; and working space is often pretty tight.  With the valve (spring) lifter, you can just push down on the valve head as you lift the spring.
Offline patack
« Reply #9 on: April 26, 2017, 05:33:16 AM »
Thank you, all, for your generous help.
Can anyone identify the manufacturer?
