Author Topic: another maybe..... ,just a regular tool?  (Read 889 times)
Offline international3414
« on: November 21, 2018, 06:50:53 PM »
this would turn a 5/16" nut or something,thought maybe someone made it out of a bolt...crazy huh...hollow thru the center.two piece handle...any thoughts?...nameless
Offline p_toad
Re: another maybe..... ,just a regular tool?
« Reply #1 on: November 21, 2018, 07:22:18 PM »
can you see how the socket is attached to the handle (inside or outside)?   since most sockets have a square opening for a wrench, maybe they squared off the "bolt" and simply soldered it in place?
« Reply #2 on: November 21, 2018, 07:35:40 PM »
i put this on the wire wheel to clean it a little,looks like one piece?...
« Reply #3 on: November 22, 2018, 11:00:56 AM »
The threads are puzzling.
I sure would not use that for any nut/cap screw that was on tight - the walls of the socket are pretty darned thin!
« Reply #4 on: November 22, 2018, 12:50:01 PM »
THE HANDLE IS TWO PIECES,LEAVING THE HOLE OPEN THRU THE ENTIRE LENGTH...
