Author Topic: Square  (Read 1362 times)
  • Administrator
Square
« on: October 14, 2019, 10:20:24 PM »
An acquaintance of mine has this square and is seeking info. I haven't seen it myself, but he says it has no maker's marks. It has holes on the arm that look like they are for a carpenter's pencil. Perhaps for layout, or marking an arc or circle.
Offline geneg
Re: Square
« Reply #1 on: October 15, 2019, 07:49:48 AM »
Seldom if ever find maker's marks on one of these.   Very common carpenter's tool & predecessor to speed squares.  The diamond shaped holes are for a carpenter pencil.  Never used one for an arc myself, but marked rip or offset lines on boards.
Offline wrenchguy
    • Wrenchguys videos
Re: Square
« Reply #2 on: October 15, 2019, 08:35:44 AM »
Mortise/tendon layout 4 post/beam construction.
  • Administrator
Re: Square
« Reply #3 on: October 15, 2019, 01:48:54 PM »
Got a quick answer from Kirk Eppler  on Facebook- Seen in a Southington Hardware catalog from 1930. Called a scribing square.
Offline jdjax
Re: Square
« Reply #4 on: October 15, 2019, 02:44:57 PM »
I used to have that same type of square. I know it had numbers stamped on it for the holes I think they were whole numbers with fractions at every hole, so if you put a pencil in the 1"1/8" hole you could scribe a line 1"1/8" from the edge of the board.
Mine did not have a makers mark either but it was very handy to use and surprisingly still square being made out of lightweight steel.
Offline jdjax
Re: Square
« Reply #5 on: October 15, 2019, 03:01:39 PM »
It is hard to tell from your picture but it looks like the end of the rule part of the square has a radius on one side and mine had that as well. I thought some knuckle head had stuck it into a grinder.
  • Administrator
Re: Square
« Reply #6 on: October 15, 2019, 03:25:04 PM »
This is the picture of the page the square is on. I don't see the radius on one side.
Online lptools
Re: Square
« Reply #7 on: October 15, 2019, 03:34:16 PM »
I can see drawing a circle, using any slot, or a spot in the oval on the head as your center point. Place a pencil at the desired radius, whether it be a slot, or the edge of the square. Not the most convenient way to draw a circle, but would work in a pinch. Regards, Lou
« Last Edit: October 16, 2019, 08:30:03 AM by lptools »
Re: Square
« Reply #8 on: October 16, 2019, 06:53:46 AM »
... I don't see the radius on one side.
Is the inside corner of the arm rounded?
Offline jdjax
Re: Square
« Reply #9 on: October 16, 2019, 08:16:40 AM »
Thanks for that Papaw.
