Hello everyone. I have an odd plier type tool for the ADT Company I would like to ID. When you squeeze the spring loaded handles it does two movements at the same time. One movement is sideways. Its made to compress a terminal or wire to hold it in place while the vertical movement sends a blunt point downward and pushes it into the top of whatever the tool is holding. Has the numbers B2351 P-24408-P1 and P-24406-P1 P-24407-P1 cast into the different parts of the tool. Thanks in advance.
