Author Topic: What is it?  (Read 528 times)
Re: What is it?
« Reply #15 on: March 21, 2020, 08:20:15 AM »
The pliers with the 2 "side cutters? still don't know.The dud is a can opener, oh well so much for it being interesting!
Got to go Thur the box more.
A bunch of pics (4200+) of tools and project in our shoppe
Re: What is it?
« Reply #16 on: March 23, 2020, 02:26:32 PM »
Thanks WVT!There are 2 of them. What is the "awl" like part for?
I've been busy with cistern prblems, no fun!
"Dynamite" type explosive in a tube -- poke a hole down the center of the explosive, insert detonator cap that has been crimped on to end of a piece of fuse, or is attached to wires from one of those "push down the handle to generate an electrical charge" devices -- then do what you have to do to be  a safe distance away when the explosive is set off.  Need to make a hole for the detonator because you don't want to accidentally cause the detonator to go off when you are in the immediate vicinity.
Re: What is it?
« Reply #17 on: March 23, 2020, 04:09:27 PM »
Thanks for the explanation! another nugget of knowledge!
Re: What is it?
« Reply #18 on: March 27, 2020, 05:54:08 PM »
These were soaked in phosphoric acid solution for a couple of days. Then clear coated.The 2 side cutters look similar, center jaws are flat.
Re: What is it?
« Reply #19 on: March 30, 2020, 06:09:26 AM »
one more pic next to a rule. 6 1/4" long
