Tighten bit into chuck, place chain feed device into a brace drill. stretch out the chain, lay to one side. Now look at the threaded portion of the shank. The part the chain is attached to needs to be spun down, away from the user, heft the drill, wrap the chain around the target to be drilled, swing the chain back and hook it. Watch as you crank the brace, the shank, chuck, and bit feed into the target, the chain part stands still. Done with the first hole, then you have to back that part with the chain hooks back down, chain up and go again for hole no.2 and so on.
