Author Topic: Need help on a small axe/hatchet blacksmith tool  (Read 2262 times)
Offline hbeaton
« on: December 16, 2014, 10:58:50 AM »
Dear Tool Talk Forum,
Thanks so much for having a forum for talking all things tool!
Picked this up recently and after doing a bit of searching on my own, I found this probably is a blacksmith's tool of some sort.
It measures 9.75" long, 4.5" head and 1 inch think on the hammer face. It appears to be hand forged.
My question is what exactly is it? Is it a hot chisel? Hammer/hatchet combo? The hot chisel idea seemed plausible but the hatchet side just seemed too big.
Figured y'all might be able to ID this a bit more. Possibly its age (relatively) too?
Thanks so much for your time. Let me know know if you need other pictures.
Best,
Hunter
« Last Edit: December 16, 2014, 11:00:52 AM by hbeaton »
Offline JoeCB
Re: Need help on a small axe/hatchet blacksmith tool
« Reply #1 on: December 16, 2014, 11:59:52 AM »
considering the short handle and battered up head, I would say it's a hot cut tool.
Joe B
« Reply #2 on: December 16, 2014, 12:01:20 PM »
Or wood splitter?
« Reply #3 on: December 16, 2014, 01:09:32 PM »
Or stone axe...
« Reply #4 on: December 16, 2014, 01:29:33 PM »
I believe it is just a small hand ax, possibly hand-forged. Hot cut tools generally don't have a cutting edge that extends beyond the width of the body....reason being that hot cut tools are struck by a hammer in use and more force will be directed to the cut if the edge doesn't extend past the width of the main body.
Just my .02 worth.
Offline hbeaton
« Reply #5 on: December 16, 2014, 02:31:08 PM »
Keykeeper,
We are thinking alike. That's the reason I posted this item. The cutting edge extends beyond the width of the body...if it was a hot cut tool or set or chisel etc then why have an "axe" head on the other side. Giving the due diligence, if it was simply a small hand ax, why this shape with the hammer striking surface on the other side. Most simple small hand axes didnt have the hammer side. Maybe a combo tool that just doesnt fit in one camp or the other?
One thought could be this was made by one blacksmith for another blacksmith for a specific use that was a bit different from simply being a hot cut item?
Guess I will wait to see what others opinions are on this item...
« Reply #6 on: December 17, 2014, 06:25:43 AM »
Could be it was purpose-built, possibly to smooth wood or remove bark from logs, with one side for a hammer to "help" it along.
I've been blacksmithing as a hobby for some years now, and just don't see a practical use this type work.
Maybe others will know, as you said.
Offline leg17
« Reply #7 on: December 17, 2014, 07:31:24 AM »
Maybe for shingling work?
