Author Topic: OK, Geniuses:)  (Read 4156 times)
Offline bgarrett
OK, Geniuses:)
« on: February 07, 2014, 07:41:57 PM »
Does anyone know anything about this letter opener?
Its labeled
"Ford Motor Company V8 First sheet thru 56 in.
Cold strip mill Dec 20 1935"
I remember reading somewhere that Ford was not able to make large sheet metal stampings until 1936 or so.
56 inches doesnt seem 'large'
Re: OK, Geniuses:)
« Reply #1 on: February 07, 2014, 08:10:41 PM »
If you read Fords history, you will run into someone named Joe Galamb.   Sheet Iron Joe, rather colorful.   Fords manufacturing capabilities while vast, seemed to be a step behind.   A lot of effort was made to keep things going just as they are.  A 56 inch wide sheet, was big for the time, distortion was an awful problem in those years, but I think this ushered in Fords solid steel top.  That is a rather unique Ford collectible.
Re: OK, Geniuses:)
« Reply #2 on: February 07, 2014, 08:14:47 PM »
I've toured pipe mills where they cut the rolls down before forming the strips into tube. The big rolls they start with seem to be around 56" wide.
I think a 56" mill is pretty big.  What part could Ford be stamping bigger than that?
December 20, 1935 for a first run seems to be pretty close (right on) to 1936 "or so."  Get your mill set up, run some testing, do a first run, work out the kinks, go on Christmas holiday, come back and start producing stampings in 1936.
Everything in your statements adds up.  Nice little bit of steel / automotive / factory history, I think.
I think your piece was made from the waste pieces in between the stampings of whatever parts they were making.
Offline bgarrett
Re: OK, Geniuses:)
« Reply #3 on: February 07, 2014, 08:18:42 PM »
The Ford Panel trucks
Offline bgarrett
Re: OK, Geniuses:)
« Reply #4 on: February 07, 2014, 08:26:07 PM »
I was guessing that they probably made a lot of these but google finds nothing. Do you really think this is the only one?
Re: OK, Geniuses:)
« Reply #5 on: February 07, 2014, 09:26:09 PM »
I am betting it was something "stamped out" for managers involved in the project, 15-20 or so, as high as 50.    Bigger than 56 inches, how about floor boards.  Seems like up til 1936 Fords used cloth tops, after that it was steel.  The panel trucks if I recall, had sides made from two stampings, upper and lower, welded joint.
Re: OK, Geniuses:)
« Reply #6 on: February 07, 2014, 09:28:58 PM »
Sorry, strip mill - I said stamp mill.  Still, 56" is a pretty wide sheet, I'm not sure where they would use the thinner gauge metal formed by the strip mill. On the panel trucks of the day, I think the roof panel may be the widest piece, just from looking at pictures. I don't know that the roof panel is much wider than that, although with the way it comes over the side it may be. It may use thicker gauge though.  The primary point is that 56" is still a large mill, especially for technology in its first decade of production level use.
Re: OK, Geniuses:)
« Reply #7 on: February 07, 2014, 09:32:09 PM »
That makes good sense. Some sort of honorable memento for the bigwigs involved at the time. Too bad that thing can't talk.
Re: OK, Geniuses:)
« Reply #8 on: February 07, 2014, 09:49:48 PM »
I've seen these "mementos" given out for promotional items also.  Could be anywhere from a small run to a very small run.
Re: OK, Geniuses:)
« Reply #9 on: February 07, 2014, 10:01:29 PM »
1936 was the 1st year of the all steel top, coupes and sedans, 37 was 1st year for panel trucks.
Dodge/Chrysler/DeSoto was the 1st all steel top 33 Airflow
Offline bgarrett
Re: OK, Geniuses:)
« Reply #10 on: February 07, 2014, 11:10:27 PM »
I knew you guys were good.   :)   I asked over on the Ford forum and have only gotten one response!
Re: OK, Geniuses:)
« Reply #11 on: February 08, 2014, 03:48:15 AM »
I can prove the dates on the panel trucks, as I have a 36 deluxe, 37 60hp, and a 37 85hp 1/4 ton panels. Yep they called them 1/4 ton but they could haul 1/2 ton with out sagging newer ones do.
Offline bgarrett
Re: OK, Geniuses:)
« Reply #12 on: February 08, 2014, 10:44:49 AM »
I have a 36 Ford Tudor and a 37 Ford panel truck
Offline bgarrett
Re: OK, Geniuses:)
« Reply #13 on: February 08, 2014, 11:40:12 AM »
Who made Fords panel trucks from 1928 to 1936?  Those are very large panels
Re: OK, Geniuses:)
« Reply #14 on: February 08, 2014, 05:13:59 PM »
That could be due to a lot of different reasons, the first three that I can think of are:
1. The bought steel that was already milled to the thickness they need from others, or others milled it thinner for them.
2.  The metal on the older vehicles was thicker - the new technology of the cold roll strip mill improved on the hot roll strip mill by allowing the steel to be rolled to a thinner gauge. I believe cold rolling can impart a more uniform finish to steel also, but I am not so sure about that.  I don't know the differences in the metal thickness or the thickness of the metal on the vehicles.
3. The metal was cold rolled on a smaller mill, it didn't need to be that big.
I think the facts are: (correct me anyone, I only claim 85% accuracy, but I may be wrong about that percentage, too.)
1.  Large size cold roll strip milling, although an early 1900's technology, wasn't really used industrially until starting in the late 20's.
2. Ford first started making large sheet metal stampings sometime around 1936.
3. The cold roll strip mill doesn't stamp, rather it thinned the metal prior to it being stamped on another machine. Conjecture: A press of some sort stamped the sheet?
4. Ford set up their first cold roll strip mill in December, 1935.
5.  Some number of letter openers were produced to commemerate the event, and were made from the first sheet milled on the new 56" cold roll strip mill.
6. Ford had vehicles with large steel panels prior to their acquisition of a cold roll strip mill.
7. Although we don't know how big the sheet was, or if other stampings were produced from it, we do know that the artifact was one of those made from the first sheet produced on Ford's first cold roll strip mill and therefore of limited production.
8. BGarrett has one of those letter openers, and it is assumed to be authentic.
Sorry BGarrett, I may have been misleading.  You asked for genius's. I used to be 90% of one, but I think I have slipped to 87.5% of one. Smartest probably have other people to answer questions for them. But I really think your letter opener is cool, is probably museum worthy, and you found one of those obscure little pieces of history that help date the technology. Thanks for recognizing it's uniqueness, for bringing it to us and for not tossing it in with the other office junk.
My finger is tired now.
PS: To an engineer the cup isn't half full or half empty. The cup is twice as big as it needs to be.
PSS: Having a mistress can be useful; your wife will think you are with your mistress, your mistress will think you are with your wife, and you can be out in your shop having some real fun.
( I may be getting a blister now. Can't tell because most of my sensory nerves are gone from my hands now.  I'll know tomorrow AM.)
Chilly out..........
