Author Topic: Ford weights  (Read 2004 times)
Ford weights
« on: April 15, 2014, 02:18:00 PM »
I have never heard of weights made by or branded with ford. The seller sais there for weighing parts.  I was wondering if he was correct or if not what there used for?
The add can be seen below. I am not affiliated with them and I am not interested in actually buying them.
http://chicago.craigslist.org/nwc/tls/4421990244.html
Re: Ford weights
« Reply #1 on: April 15, 2014, 02:23:52 PM »
picture from add
Re: Ford weights
« Reply #2 on: April 15, 2014, 03:06:07 PM »
I almost bought a chain fall that was marked FORD,
It turned out to be made by Edward Ford, no relation to Henry
I dont see any ford script or motor co on these weights
Re: Ford weights
« Reply #3 on: April 17, 2014, 10:26:04 AM »
At first I thought that it was not likely that Ford would run such a short batch of weights.  Then I noticed that the weights were adjusted by drilling and /or adding lead. This is as opposed to milling or having a more refined method of casting.
So now I think that they were probably made in a short casting run. Then they were adjusted and cleaned up.
I think it is possible, even likely that they were made by Ford.  Too bad there isn't better provenance.
Re: Ford weights
« Reply #4 on: April 17, 2014, 12:30:13 PM »
There was an English scale maker named Ford - cast iron weights bearing his name are known to exist...
see: http://home.clara.net/brianp/namesej.html
