Author Topic: Old RCAF Wrench - Terry's Spanners  (Read 9881 times)
Re: Old RCAF Wrench - Terry's Spanners
« Reply #15 on: June 23, 2014, 10:30:28 AM »
Are you positive?
At my age, it kind of depends on a lot of things.  J/K.
Are you sure it is positive to earth, or just positive ground? Is there a difference?  I mean, I can see using a frame aspositive lead, but the electricity will still flow from negative terminal to the positive one I would think.  I dont see how you can ground to earth on a motorcycle with a closed dc circuit.
Am I just missing the meaning of earth vs ground?
Larry
Offline nick
« Reply #16 on: June 23, 2014, 12:17:37 PM »
most of the older International Harvester tractors had Positive ground  C,M,MTA
« Reply #17 on: June 23, 2014, 02:40:55 PM »
you stand on the earth !
you stand on the ground !
my 1941 Farmall A has positive ground.  I bought a 6-volt positive ground
alternator to install in place of the generator. (another project)
back in my younger days, some of my automobiles had positive (+) ground,
I belive my early Fords were such. 1940-1941's
« Reply #18 on: June 23, 2014, 02:46:24 PM »
I just happen to think that my 1949's & 1950's Fords also were still (+) ground.
« Reply #19 on: June 23, 2014, 04:41:50 PM »
Yupp!  Positive earth!! Many words were different!; Spanner, bonnet, Boot, Bulkhead, Damper, dynamo, fascia, kerb, megger, petrol, scuttle, swarf, trafficator, wing (fender)...  etc..  When you work on foreign cars, you need to learn the terms...
« Reply #20 on: June 23, 2014, 06:22:47 PM »
Thanks Guys
BTW -Why is most modern stuff negative grounded? Is there any difference?
« Reply #21 on: June 23, 2014, 10:00:29 PM »
How about the term, Strangler Valve.  On this side we called it the choke.   What I find amusing is when we had stagecoaches, the luggage was put in the boot.   But when we started with automobiles, a trunk was strapped on the back and it just became the trunk.  Winter coats have hoods, but at one time a hood was a folding top for a delivery wagon.   Since vehicles are often referred to as her,  the British used the term bonnet for engine covering, while we stayed with the somewhat male, hood.   A common people separated by a common language.
« Reply #22 on: June 24, 2014, 03:31:31 AM »
Am I just missing the meaning of earth vs ground? Larry
In the UK we tend to use the term earth for the yellow/green wire in a mains (AC) cable - that's connected to the earth pin of a plug, and the wire in the socket goes back to the consumer unit (fuse box), and from there to a spike stuck in the ground/soil/earth...
In theory the -ve (in the UK blue) wire is at 0 volts, and thus at earth/ground potential, and in many systems the neutral wire is grounded to earth before it enters the building..
On a vehicle the chassis/frame/body is considered the earth - as these are mainly DC systems it doesn't matter whether the earth is +ve or -ve, as long as all components e.g. battery/generator are connected the same way around... It may have some slight effect on corrosion at jointing surfaces. When vehicles went from generator to alternator, and from 6v to 12v systems most manufacturers changed from +ve earth to -ve earth..
« Reply #23 on: June 24, 2014, 11:31:52 PM »
Thanks Guys
+positive earth encourages galvanic corrosion of the surrounding bodywork - whereas with negative earth is much-easier-to-replace electrical contacts that corrode.
Old copper wires weren't coated & would stiffen & corrode, but now all copper wires are coated so not a problem...
« Reply #24 on: June 25, 2014, 01:34:41 AM »
Sparking plugs.
Offline Batz
« Reply #25 on: June 25, 2014, 03:45:42 AM »
A lemon.
Ever owned one?
« Reply #26 on: June 25, 2014, 04:51:55 PM »
Another thing to ponder, the very early cars used dry cell batteries to run the ignition, the zinc case is positive, so you would want your car positive grounded so the battery wouldn't short out ...
Rechargeable lead/acid batteries don't have an exposed conductor, so this became totally unimportant..
