Author Topic: Reinhard McCabe Model 10  (Read 1510 times)
« on: July 04, 2014, 03:39:07 PM »
Picked this up today and found a couple others and there is one slight difference,
mine has a catch that sticks out at the end of the teeth on the handle and these two don't,
so is the one I have a newer model?
Top 2 on the left; http://www.greatplanestrading.com/MVWC/MVWC11_347CW.jpg
Re: Reinhard McCabe Model 10
« Reply #1 on: July 04, 2014, 04:41:20 PM »
I think you are right.  Pinching pennies probably. Saved the additional rivet on the handle.
« Reply #2 on: July 04, 2014, 06:17:17 PM »
Neat , one more thing to look for.
« Reply #3 on: July 04, 2014, 08:57:51 PM »
 Interesting. Since I.m putting ! hole in body,is it cheaper to put a second hole in body and add a rivet ? Assuming body is stamped out the radii of the projection look pretty tight. I guess the answer is I don't know which is cheaper. Better do a cost analysis. I have one of those wrenchs somewhere. I'll look for it tomorrow(not at first light however)
« Reply #4 on: July 05, 2014, 01:21:25 AM »
The tab is part of the original stamping.  Even if the holes are stamped out you still have to put in a rivet.  I think they should have pressed out a little dimple. They could have put a smiley face on it, whaddya think?  Maybe they broke their rivet machine and it was a different one from the handle riveting machine?
Seriously though, it looks like the rivet handle tools don't have as pronounced thread as the tabbed wrenches.  Could be picture quality though.
« Last Edit: July 05, 2014, 09:05:08 AM by Chillylulu »
« Reply #5 on: July 05, 2014, 07:01:39 AM »
I think it is an earlier model. With the tab you have to final assemble the moving jaw onto the main body and upper jaw piece. With a rivet stop you can pre-assemble the lower jaw assembly and slide it onto the main body and then add the rivet if it is a stop. The tab model also creates a pinch point for the palm of your hand. Just my take. :smiley:
« Reply #6 on: July 05, 2014, 09:08:31 AM »
Lewill2 makes a good point. Another factor is the patent pending on the tab model. I can't make out writing on the riveted ones.
