Author Topic: Whatsit Used For ?  (Read 4087 times)
Offline DobroDan
Whatsit Used For ?
« on: July 15, 2014, 09:18:45 PM »
Hi All:
First post.  I have a typical Schollhorn/ Bernard's parallel jaw pliers Pat. 1890, 1901 and 1903. I have seen many photos of these with all sorts of  "jaws " for different functions. This one is different in having rotating jaws that do 6 different functions. Also it is stamped LAKE-ERB MFG.CO. NEW YORK, N.Y.  U.S.A. under this are the 4 letters U.E.T.C. I have seen 1 other stamped LAKE-ERB but it was a single function pliers for crimping ends on wires.
Any info on it ?   Dan
Offline Mitch
Re: Whatsit Used For ?
« Reply #1 on: July 16, 2014, 03:21:01 AM »
It looks like a rotary hole punch for leather working.
Love my Bonney and Plvmb"s!
« Reply #2 on: July 16, 2014, 09:38:17 AM »
 Bernard made a No. 240 eyelet setter which had revolving heads and looks very similar to your tool.
Offline DobroDan
« Reply #3 on: July 16, 2014, 10:07:05 AM »
Jimwrench:
3 of the 6 functions look like 3 different sized eyelet setters. the other functions are a 1/2 inch wide sharp cutter that hits a flat surface and a 1/2 inch wide by 3/16 inch long flat ended male part that fits snugly into a 3/16 inch female grove. The last one is a 1/2 inch wide male that fits into a larger female and when closed leaves a round opening about 3/16 in diameter.
Any idea what the last 2 are intended to do?  Thanks,  Dan
« Reply #4 on: July 16, 2014, 01:16:04 PM »
 No clue but assume it would have a function related to what they were setting eyelets in.
« Reply #5 on: July 17, 2014, 01:24:33 PM »
Lake Erb Mfg is listed in the Auto trade magazine under 'Tools, Terminal forming'
So my guess would be a tool for forming brass wire end terminals of various types...
Here we go...
Offline DobroDan
« Reply #6 on: July 18, 2014, 10:03:49 AM »
rusty:
Thanks - I think you found the first model!! Mine appears to be a slightly improved one with an added ferule squeezer for smaller wires.
Do you have a approximate date for the ad that you sent?
Thanks again,  Dan
« Reply #7 on: July 18, 2014, 05:22:33 PM »
oops, sorry, the ad is from 1922 issue of The Automobile Trade Directory.
(Volume 20, Issue 1 , Page 875)
I see ad references only from 1921 to 1923...
Another mag notes: LAKE-ERB MFG. CO.. INC.—332 W. 58th St., New York. N. Y. Manufacturer of wire terminals. pliers. etc. President, James Lake. Jr.: vice-president and manager, George G. Erb; secretary and trrasurer, Alfred 0. Lake
(They moved from  405 Fourth street to 332 West 58th street in 1922)
They seem to have sold using the name B&E also
Also found them listed as making ammeters
Offline pritch
« Reply #8 on: July 19, 2014, 11:04:49 PM »
I'm no help on the tool, but let's hear about the Dobro, Dan...
Offline DobroDan
« Reply #9 on: July 24, 2014, 10:35:09 PM »
That's a long story, pritch, but I will tell you the next time we have a beer - OK?
I think rusty nailed that eyelet and ferrule pliers and it's time period. Goodonya rusty!!! To keep the thread alive here are a couple more Whatsit Used for's.
The first is marked :   NO  55     THE CARBORUNDUM COMPANY    NIAGARA FALLS  NY  USA  on the wooden part of the handle. the detachable end piece is marked ST97   498SH and the end is      1 3/4 inches in diameter, very smooth and slightly convex.  The other 5  end pieces would fit a handle with a smaller diameter. The three above are marked SMHS404-6, -5, and -4 (L to R). The two ends below are not marked.
The second is not marked and looks like a very large offset screw driver to me - compare him to his smaller cousin.  The ends are flat a little over an inch wide a little more than  1/8 inch thick.  Are there other uses ???
Offline ron darner
  • RIP 4-18-1941- 9-30-2014
« Reply #10 on: July 24, 2014, 11:20:09 PM »
Lower one makes me think of a drag link adjustment tool, though all I've seen were made as sockets with a giant screwdriver tip (straight blade).
« Reply #11 on: July 24, 2014, 11:58:47 PM »
The pins kind of remind me of punches, except they are so long....
« Reply #12 on: July 25, 2014, 05:31:43 AM »
Kind of looks like air impact tools with a hand driver tool...
« Reply #13 on: July 25, 2014, 06:53:59 AM »
The pins remind me of a valve guide installer set.
