What's the deal with this arbor press?
Started by Twilight Fenrir, August 05, 2014, 12:48:57 PM
Chillylulu
Quote from: oldtools on August 08, 2014, 12:46:13 PM
Also need to consider the square inch of press...  2 tons over 1 Square inch isn't hard, considering a high heal shoe spike can apply ~1 ton pressure over 1/4" sq.....
In this case it is quite a lot.
I don't understand the high heel analogy, could you help me? Is the wearer very large, or are you referring to stomping or something like that?
Twilight Fenrir
Quote from: Chillylulu on August 11, 2014, 03:09:07 AM
Well, that's a bit of an exaggeration, but right in principle...
If a person weighs 200 lbs is standing on 1/4" spike, that's 800 psi. Doesn't quite work out that way, because SOME weight is on the front of the shoe, and there are two heels. If you narrowed the heel down to a real spike, pointy and all, could clear 2k psi easily, I suspect.
oldtools
Quote from: Twilight Fenrir on August 11, 2014, 07:01:19 AM
Yes, but to show the "point", that you Also need to consider the "square inch of press" are you pressing more than 1" square? or less
1" sq. is 16 1/4" sq. ( 4X4), so 16 X 200 is 3200#, (granted she is standing on 1 heel.)  something to think about...
Twilight Fenrir
Quote from: oldtools on August 11, 2014, 09:52:30 PM
.... Right you are... I never did do very well in geometry XD Could throw algebra at me all day long, but for some reason, geometry just never stuck...
Chillylulu
Quote from: Twilight Fenrir on August 11, 2014, 10:09:21 PM
Except, gentlemen, psi isn't relative to the presses rating or to the way it increases power.
It is two different concepts and isn't usually used when talking about this type of work /tool.
If you are talking hydraulics, especially closed systems, then we are in business. And I can help a lot there. Thats what I get paid to do.  Well, that and being eye candy.
