Author Topic: It's heavy, but what is it?  (Read 13213 times)
Re: It's heavy, but what is it?
« Reply #15 on: October 21, 2014, 08:25:13 PM »
it is also possible that someone got ahold of the tool and tried to use it on something
other than a sappling.
I think that it would be easier to push this tool into the sappling rather than pulling a blade type.
I had read somewhere in the past that they would cut big bundles of sapplings to the length
that they would be needing for certain barrel orders.
if I recall correctly, when they were needed, they would soak them before splitting them.
sometimes beating on them to make them softer before splitting. ( if my memory is correct.)
I have a sappling hoop notcher somewhere in my cave,  it is supposed to be foot operated, but
when I got it, the wood frame was cut down and the foot pedal, long rod & spring was missing.
when I get a chance, I will try to locate it,  ( I had looked up the patent to see what was missing.)
« Reply #16 on: October 21, 2014, 08:31:00 PM »
I forgot to mention that the hoop notcher makes a slight cut on the ends, then with
a damp hoop, you put it around the barrel, cross the cut notches, and they lock, then
when the hoop dries out, it is real tight around the barrel.
« Reply #17 on: October 22, 2014, 06:47:26 PM »
There's an excellent video on Youtube of Camille Gauthier, a retired merrandier in France, showing how he made merrains (the blanks from which the cooper made the barrel staves) from a large (and straight grained) oak log...
He effortlessly splits a large oak log down the centre with a wedge and maul - for smaller barrels (e.g beer casks), smaller logs and smaller staves, rather than thick staves used for wine barrels, I could see this tool being rammed into the end of a log to split it into three pieces suitable for further work with a froe - it's own mass, and a stong arm, would give it a lot of kinetic energy...
For the video, see:  http://www.youtube.com/watch?v=jsei4x9uXH4
To my mind, that makes more sense than using it to split saplings to make a barrel hoop - it's so easy to split a sapling up to about 40mm (1.5") with a billhook, there's no need for another tool... Thatching spar makers and hurdle makers in the UK can keep  the split to the centre of the gad with a twist of the wrist....
« Reply #18 on: October 22, 2014, 06:52:43 PM »
There's no need to place the hoop on damp - the barrel shape lends itself to the hoops being driven on and self locking (as with the iron hoops) - in France they still use wooden hoops (cercles) (as well as the metal ones) to roll the barrel on - they also look more decorative...
the second image is better - from the tonnelerie Gillet in Bourgogne: http://tonnellerie-gillet.com/home/index.html
« Last Edit: October 22, 2014, 06:55:49 PM by Billman49 »
« Reply #19 on: October 22, 2014, 09:22:26 PM »
I agree that it is easier to drive a metal hoop on to keep it tight, but, before the use of medal hoops,
they knew how to use sapplings.  and they would need to let them dry to tighten.
if you tried to drive down a hoop made out of sapplings, they would break.
I am thinking of the early barrel makers.
we would have to research the timeline for making hoop drivers.
just my opinion.
« Reply #20 on: October 23, 2014, 04:26:05 AM »
Many UK coopers used trussing hoops, made of wood, driven onto the barrel with hoop drivers and a mallet or hammer - these were heavy in section, much more so than the wooden hoops used to hold the staves in place. They continued to be used even after metal hoops were common, and as far as I know are still in use by the few working coopers still making barrels for breweries and whisky distilleries..
In France the cerclier worked in the chestnut woods, cutting, riving and bending the wooden hoops (cercles) - like the merrains produced by the merrandier, these were delivered to the coopers (tonneliers) in a rough and unfinished state, but in the case of cercles, I would imagine while the wood was still green, and relatively pilable.. The cooper did the final shaping, sizing and fitting..
See also: http://www.forum-outils-anciens.com/t7262-Les-vieux-M-tiers-St-Gervais.htm?q=cerclier and http://www.forum-outils-anciens.com/t1172-Queue-d-hirondelles.htm?start=60 (page 5)
« Last Edit: October 23, 2014, 04:39:27 AM by Billman49 »
« Reply #21 on: October 23, 2014, 10:02:44 AM »
The earliest illustration of a hoop driver I have found so far is a Medieval drawing.  Along with several
Renaissance illustrations, and a circa 1909 photo of a Russian cooper, these are being used to drive
down sapling hoops.  The drivers are all made of wood.  Wooden drivers were still being produced by
L&IJ White.  Saplings, in fact, do not break on being driven.
There isn't enough longitudinal shrinkage possible to make a barrel sufficiently tight.   It's not a matter
of being "easier" to keep it tight.  It's necessary to making a barrel, or a bucket, or a wash tub.  You
have to drive them very tight to force the staves together.
« Reply #22 on: October 23, 2014, 10:25:08 AM »
Notice the truss hoops in the L&IJ White catalog.  These are the wooden truss hoops that Billman mentions.  They are used for forming the barrel, forcing the curve into the sides of the barrel and compressing the joint to the point of being watertight.  The hoop-drivers are struck by  cooper's hammers that weigh an average of 4 pounds (or a large, heavy mallet in Medieval and early Renaissance times).
« Reply #23 on: October 23, 2014, 01:09:07 PM »
German coopers from 15th, 16th and 17th century driving wooden hoops... Note how the all wooden driver becomes more tool like and less like a piece of scrapwood...
« Last Edit: October 23, 2014, 01:17:12 PM by Billman49 »
Offline bear_man
« Reply #24 on: October 29, 2014, 02:10:37 AM »
Billman, thanks very much for the YouTube video link!  I especially enjoyed watching the white-haired gentleman using his froes and shaving horse.  At this date (I'm working on 70 years now) I'm gonna skip learning French, but I could ALMOST wish I'd learned it so's to understand what he says about his froes and methods/madness.   *bear grins*   I've saved the link and will go back and watch some of the "recommended videos" during deeper winter.
     Oh, one reason my interest was piqued is that I own a froe-and-mallet set from an early Finnish, "White" settler here in the panhandle of Idaho.  He used the pair to make shingles for his late-1800s cabin out of I-don't-know-which wood, just as my former Hispanic neighbors in New Mexico did, but out of what they called "Sugar Pine."  I'm saving the pair and provenance on them for whenever someone begins talking about a local museum of whatever size.  Thanks again.
Offline Charles Garrett
« Reply #25 on: October 29, 2014, 10:50:33 AM »
We usd to have tool meets at Dale Kirby's barrel factory at a somll town nr Moberly, Mo.  He had his people demonstrate for us.  Really neat as all the machinery was over 100 yrs old.  The one thing I really thought was neat was when he chucked up a barrel and sanded it with a belt sander that was abt 10' long and there was a large hole in the wall w a fan and the dust was blown OUT.
« Reply #26 on: October 29, 2014, 12:32:43 PM »
Hi Bearman, glad that you enjoyed the video link - I write French reasonably well, but my spoken French is poor, so I also have great difficulties understanding the narrative - but as they say " actions speak louder than words" - and he is a pleasure to watch...
I've just found this image of a tonnelerie, showing the wooden hoops, driver and mallet still in use well into the 20th century....
« Last Edit: October 29, 2014, 12:36:31 PM by Billman49 »
« Reply #27 on: October 29, 2014, 03:11:58 PM »
Thanks Billman for all the insight into barrel making.  Even though I understand no French, I enjoyed the video.  That guy was amazing, didn't look like he broke a sweat.
« Reply #28 on: December 04, 2014, 08:51:17 AM »
Coopers' hoop splitters.  But we had only part of the story.   A new book I have on Russian coopering shows ones that cut into thirds, and ones that cut into quarters.
The rest of the story is that in use, the triangular back created by splitting is shaved flat with a drawknife as part of the process in forming wooden hoops from saplings.  This provides a lower profile for the hoops.  Splitting in half makes the profile thicker than desired.
« Reply #29 on: December 06, 2014, 05:22:28 AM »
It seems overkill if these tools are used for splitting sapling to make hoops - someone may have seen the wooden tools used by basket makers to split bindings, and though they'd scale it up to this best...
In the UK spar makers and hurdle makers just use a billhook to split the gad (spar) or rod (hurdle)..
see: https://www.youtube.com/watch?v=U08AiNxq17Q he only uses the billhook to start the cleaving
https://www.youtube.com/watch?v=K3TnwYDKhY0 this chap just uses a billhook for spar making.. My old mate, George Day, from Shaftesbury in Dorset would make up to 3000 per day (it took him another day to cut the gads)....
