Odd Saw Set
Started by wvtools, February 12, 2015, 07:19:14 PM
wvtools
The point is fairly sharp, but it is more like a rip saw tooth.  It does not come to a point, and it is not sharp along the edge of the disc.  The disc on mine looks like the one edge could have been broken off or reground.
I just tried it out on a pencil.  I think it may be set up for a larger pencil, but I am thinking it is for crimping on the pencil eraser ferrule or a similar operation on a similar sized ferrule.  The depth stop would make sense for that as well.
thiggy
I was reading about the history of Millers Falls tools which eventually morphed into an earlier iteration and when I saw this, I thought that I had just seen one earlier this week.   http://oldtoolheaven.com/related/goodellimg/cutoff-tool-lg.jpg
Billman49
Now we know who made it (Goodall Brothers) and what it' called (cut-off tool), we just need to know WHAT it was used for...
Bill Houghton
More clues: http://www.wkfinetools.com/hUS-borTools/GoodellPratt/hist-GBrothers/GB-Hist-13.asp (scroll about halfway down the page).  This implies, to me, metal cutting work - why would anyone bother to make a cutoff tool for 1/2" wood stock, when you can cut it off so quickly with a skew?
So, this was apparently designed for hand-held use on round stock held in a lathe.  Interesting indeed.
bill300d
#19
So now that we know who made it I found this in Goodell's catalog no.16 on page 391 which I believe is from 1926.
Looks like your missing the length gauge but probably still usable as is.
turnnut
back in 1904 it sold for $2    then in 1926 it was only $1.50
in 1904 it was most likely a time saver for them to cut many pieces.
they might have been cutting them with a hacksaw, then with this tool, they
could put a long rod in the lathe and just keep cutting.  and with the stop, all
pieces would be the same length.
with the hacksaw, they would have to measure/mark each piece to cut.
just my 2 cent thought.
wvtools
Thanks for the good work guys.  I may have to redo the auction.  I would think I could get a 9.99 opening bid now.
Thanks,
John
