Author Topic: Dixie "Hair Straightener/Blacksmith Tool/Bullet Mold "  (Read 6149 times)
Offline PFSchaffner
    • VintageMachinery profile
« on: September 08, 2015, 11:05:12 AM »
The subject line is the description from an ebay listing for a similar tool, which fairly
represents the confusion on the web about this thing. On the Bolt's Tool Museum
site, the conclusion seemed to be that it was a heat sink (though no justification
of the "Dixie" name); in many comments it is asserted that these things began life
as hair straighteners and were re-purposed by Dixie gun works as blank bullet molds
(but with no evidence).  Now I get one in the incoming donations. Has the world
reached a consensus? (the nose pieces are solid, the faces smooth and flush.)
pfs
member: TATHS | MWTCA | EAIA | MVWC | CRAFTS
tool-cleaner and -sorter, Ann Arbor Kiwanis Thrift Sale
Re: Dixie "Hair Straightener/Blacksmith Tool/Bullet Mold "
« Reply #1 on: September 08, 2015, 01:21:30 PM »
Solid faces wouldn't be any good for a bullet mold. And, the blue paint is certainly not Civil War era.
« Last Edit: September 08, 2015, 01:24:29 PM by Papaw »
Offline PFSchaffner
« Reply #2 on: September 08, 2015, 01:52:06 PM »
The theory (not my theory!) was that they are 'blanks' and would have
to have the correct size bullet aperture machined into them. As a production
process, this seemed unlikely to me. The theory may be based on
the fact that Dixie Gun Works is a modern maker of reproduction (and other)
black-powder firearms. Several people report that "Dixie Gun Works bought
these used wherever they could find them in their early years & sold them
as bullet molds. They would machine them to your specs or sell them to
you as is."  Maybe.
(The blue paint is mine. They started out with red-painted handles,
equally modern, but the paint came off in the de-ruster bath. For my
purposes, especially with modern things like this, I rarely care about
preserving original colors and/or patina.)
Throwing out the bullet molds leaves us with hair straighteners or curlers
(a kind of flat curling iron); the same idea, applied to fabric (buttonhole or
riibbon iron); and heat sinks, or something else entirely.
The Bolt's discussion is here
http://www.boltsantiquetools.com/tool_lovers_club_tlc001-tlc0025.html
relative to item TLC0019 (which are "DIXIE No. 2" whereas mine are "DIXIE No. 1".
Another discussion here:
http://toolmonger.com/2011/07/22/questionmonger-what-is-this-tool/
I am most persuaded by those who see the large heads as designed to
retain heat, either as heat sinks (I can see using these to hold wires
during soldering...) or as hair-pressing or  buttonhole irons.
Reading these widely scattered discussions is entertaining,
mostly because of the number of people who are absolutely sure of
diametrically opposed solutions.
pfs
« Reply #3 on: September 08, 2015, 01:53:52 PM »
Damned if I know, but  I damn sure wouldn't play with it, especially if it was hot.
That thing looks like it has high ouchie potential.
Offline PFSchaffner
« Reply #4 on: September 08, 2015, 02:05:37 PM »
I refrained from mentioning the theory that these are castration tools.
pfs
« Reply #5 on: September 08, 2015, 03:12:42 PM »
I ran across one of these at a sale on Labor Day.  Left it on the counter.  When I picked it up, I expected recessed surfaces that would accept a pill for an uncooperative pet.  No such luck.
No idea at all--except that it would have been swell when I was a kid--to put cap gun strips in and whack on the sidewalk.  Much better than the pliers I used.
Offline PFSchaffner
pfs
Offline Twilight Fenrir
« Reply #7 on: September 08, 2015, 08:21:25 PM »
Another discussion, equally speculative:
http://community.ebay.com/t5/Archive-Collectibles/Does-anyone-know-what-this-tool-is/td-p/17864901
Whoa... I've been using eBay forever... and I didn't know they had a forum type setup XD
From what searching I did... hair curling seems to be the winner most of the time.... here's and old diagram that shows a similar (definitely not identical, but give or take 200 years :P) But, I suspect they were originally made for hair, and when they were put to other uses, they were modified and altered...
Yours are clearly industrialized, and meant for something entirely different. All those sharp angles around the joint would catch and pull hair something fierce.  Definitely NOT a  blacksmith tool, though....
Also, Dixie does list a Mould with no cavity still...
http://www.dixiegunworks.com/product_info.php?cPath=22_101_283&products_id=14103
« Last Edit: September 08, 2015, 08:32:07 PM by Twilight Fenrir »
Offline PFSchaffner
« Reply #8 on: September 09, 2015, 03:14:31 PM »
Thank you Twilight Fenrir (with your ragnarocky name).
Yes, I think the hairdressers have the upper hand. I shall henceforth think of this tool as a pinching iron. I suspect that the term and the tool are a bit generic: i.e., it could be used to 'pinch' other things than hair, even from the beginning.
First illustration below from: Hairstyles: a cultural history of fashions in hair from antiquity up to the present day; illustrated with objets d'art from the Schwarzkopf collection and international museums / Maria Jedding-Gesterline (1988). Copy taken from Google books snippet.
Second illustration (which seems to nail my tool pretty exactly) is from Modern Beauty Culture / Adelaide Smith, Reuben Rockwood (Prentice-Hall, 1934), p. 201; copy taken from HathiTrust.
There should also be a picture in A. Mallemont & Mark Campbell, The Techniques of Ladies' Hairdressing fo the 19th century : a compilation of original 19th century sources. (LACIS, 1996), p. 68. [Missing in Google snippet view.] Perhaps also in Victorian Houseware, Hardware, and Kitchenware : a pictorial archive / Ronald S. Barlow (Dover, 2001).
Pinching irons in use:
1. To curl hair in papers.
"Soft and fluffy gray hair often looks much better curled or crimped. If hot irons are used for this it will yellow the hair. ... It is therefore much better to do the hair up with papers or pins over night. If the iron is used at all, a very good effect may be obtained by weaving the hair on pins and covering the hair on each pin with tissue paper, before applying a pinching iron. Great care should be taken, also, not to have the iron too hot." -- Grace Murray, The fountain of youth: or, personal appearance and personal hygiene (New York, 1905).
"In curling the front hair or bangs, each lock may be twisted in a little papillotte, or a bit of paper, and then pinched with a 'pinching iron,' which is made to press between its two hemispheres a little flat curl." -- Beauty, its attainment and preservation (New York, 1892). [identical passage in The Delineator, July 1900]
"The secret of safe hair-dressing is never to pull the hair, never scorch, and always wrap a lock in paper before applying the iron. Common round curling-irons and frizzing-tongs may be safely used if thin Manilla paper is folded once around them. So in crimping: the hair may be done up on stout crimping pins held by slides, or braided in and out of a loop of thick cord, a bit of thin paper folded over the crimp, and the pinching-iron used with safety every day, providing the hair is not pulled too tight in braiding it The country method, where friseur's irons are unknown, is to lay the head on a table, and set a hot smoothing-iron on the woven lock -- an awkward but efficient process." -- Mrs. S. D. Powers, The ugly-girl papers, or hints for the toilet [from Harpers Bazar] (New York: Harper, 1874).
"Do the hair upon stout crimping pins, or braid it in and out of a loop of thick cord; fold a piece of thin paper over the crimp, and the pinching iron may be used in safety." -- Ward and Lock's Home Book; forming a companion volume to Mrs. Beeton's Book of Household Management (London, 1882?) [also published as Sylvia's Book of the Toilet : a lady's guide to dress and beauty.]
"HOW TO CARE FOR THE HAIR. I would advixe curling the bang by rolling it on a lead-pencil, putting papers over it, and then using a pinching iron, for this will not--unless one is absolutely careless--injure the hair in any way." -- Ladies' Home Journal v. 8 (May, 1891)
2. In baking.
"Mutton patties ... Line a dozen or more tartlet moulds with the trimmings of puff paste; fill them with the meat; cut out the cover, from the centre of which cut a piece the size of a wafer: pinch the borders all round with a pinching-iron." -- John Simpson, Simpson's Cookery, Improved and Modernised (London, 1834).
pfs
« Reply #9 on: September 09, 2015, 03:33:21 PM »
 Sellens in his Dictionary of American Hand Tools shows this tool on page 327 Lists as Pinching iron: Hair drying and Pinching comb and hair pincers. His description:A tool used to remove the curl from a strand of hair. The tool is pinched over a small lock of dampened hair and the hair is then pulled thru the iron. It can also be used to set a ringlet curl in a lock of hair. The working end consists of two flat surfaces approximately one inch in diameter. The tool is heated during use.
« Reply #10 on: September 11, 2015, 12:20:41 PM »
Here's a few more, but just to confuse matters, I saw a similar pair the other day, only the jaws did not touch - in the fully closed postion there was a 6mm (1/4") gap between the faces...
« Reply #11 on: September 13, 2015, 05:43:05 PM »
That's for people with really thick hair.
« Reply #12 on: September 13, 2015, 10:04:08 PM »
Ain't neither.
Those were for inserting the hot iron spoolie which was replaced by the plastic spoolie.
