4 tools we can’t figure
Started by Badknuckles, April 09, 2016, 02:51:36 PM
Badknuckles
Hello. Well it's been a while.
We have 4 tools we can't figure. Here is the first. It can be closed either way. There was a lot of model T stuff too if that's a clue. The inside of the handle is roughed up for a good grip on something. The blade does not move as the handles rotate.
Bill Houghton
If in doubt, it must be a nutcracker.
But where are the other three tools?
gibsontool
Pics are a little hard to see. Maybe some sort of crimper ?
Badknuckles
Here's a couple more views. Sorry about the art work - I couldn't get the Irfanview Paint function to work my way today.
Looks to me like you might insert the prongs into a slot in a small gizmo then grip it with the handles. It evidently takes 2 sizes; 1/4 and 1/2 inch.
If I'm doing the pics wrong please tell me how to correct it.
Plyerman
You did the pictures just fine. But I still don't know what it is...?
Northwoods
Initials   H  M  Q  on there anywhere?
Badknuckles
Cleaned it off really good - no initials or clues.
Northwoods
Google HMQ and nutcracker.  Really neat story there.
Badknuckles
Bill-
Right on!! It's a nutcracker. I just assumed you were kidding. I got the answer on an antique forum. Here is a quote and a pic showing a similar piece. The age and value wasn't discussed.
>>So far I have found over 10 and they are all located in the United Kingdom and most are referred to as from Victorian to early 1900's.  This has been referred to as a "Reversible hinge" or "double jointed" nut cracker.  Can be used either way you flip the handles and the end/hinge piece helps hold the larger or smaller nut!  The protruding gaped & tall one is also used to help pry the shells apart!<<
Bill Houghton
Well, I wasn't kidding so much as guessing wildly.  Glad you tracked it down.
