Author Topic: Calling all Plier Guru's  (Read 2196 times)
Offline Bad 31
« on: March 05, 2017, 10:14:43 PM »
What is it and does anyone need it? Two different pliers fell into my bucket this weekend. The only marking I can find on #1 is: 08W0 cast into the handle and it's 8 1/4" long. #2 says C.S. Osborne & Co. Harrison, NJ and it's 7" long.
#1 -
#2 -
Offline Catch22!
Re: Calling all Plier Guru's
« Reply #1 on: March 05, 2017, 10:27:09 PM »
First one looks like a Nut Cracker.  Cant see the top in the pictures.
Offline Ken W.
« Reply #2 on: March 05, 2017, 10:27:52 PM »
The top one looks like mig welding pliers. The bottom one looks like tire chain crimpers or hog ring tool.
Offline Bad 31
« Reply #3 on: March 05, 2017, 10:34:23 PM »
Thanks Ken, I'm not a welder so that was a new one for me. Looked them up on line and it looks like an exact copy.
« Reply #4 on: March 05, 2017, 10:52:40 PM »
I think Ken W. has it right mig welding pliers and C.S. Osborne made leather and upholstery tools so hog ring pliers it is.
« Reply #5 on: March 06, 2017, 08:14:46 AM »
I could use the welding pliers.  How much will they cost?
« Reply #6 on: March 06, 2017, 01:14:01 PM »
Agreed.
« Reply #7 on: March 06, 2017, 01:32:51 PM »
Curious: what are the requirements of MIG welding that call for that particular plier design?
« Reply #8 on: March 06, 2017, 02:28:40 PM »
Hog ring pliers but with that smaller head, be great for upholstery work.
« Reply #9 on: March 06, 2017, 03:42:31 PM »
being an Osborne tool, most likely was for upholstery work.
« Reply #10 on: March 06, 2017, 06:11:21 PM »
The MIG pliers are made to disassemble the MIG welding gun head for cleaning and repair.
« Reply #11 on: March 06, 2017, 06:13:02 PM »
Bill H
here's a pretty good explanation of mig pliers from over at the Welding Web forum.
mig pliers uses
    1) Cutting off the burned wire before starting a new bead.
    2) Removing the contact tip from the gun.
    3) Cleaning spatter out of the gun nozzle.
    4) Removing the gun gas diffuser.
    5) Holding down a print so it doesn't blow away.
    6) Propping up a piece to hold it in place for welding.
    7) Pulling out pesky nose hairs
    8) . . .
« Reply #12 on: March 06, 2017, 06:15:25 PM »
The Osborne catalog that I have lists those as the No. 440 Hog Ring Pliers for setting standard hog ring clips.  I think they are referring to those small hog ring like clips used in upholstery work, particularly automotive upholstery, which are smaller than a regular hog ring used on hogs.
