Author Topic: Barcalo wrench iron bronze alloy?  (Read 1746 times)
Offline Markk
« on: January 06, 2018, 12:05:46 PM »
This tool is magnetic however it does have a goldish copper color to it. At first I thought it was nonsparking because of the color but due to its magnetic properties I’m not sure. Could be some strange cover LA this tool is magnetic however it does have a goldish copper color to it. At first I thought it was nonsparking because of the color but due to its magnetic properties I’m not sure. Could be some strange copper alloy?
BTW, this Is my first time posting and I hope my post in the right place!
Offline kwoswalt99
Re: Barcalo wrench iron bronze alloy?
« Reply #1 on: January 06, 2018, 12:06:52 PM »
They probably didn't finish plating it.
« Reply #2 on: January 06, 2018, 01:04:59 PM »
Hi Mark, welcome to Tool Talk.
« Reply #3 on: January 06, 2018, 05:58:42 PM »
Barcalo has some wrenches that are nickel plated giving them a yellowish look compared to silvery chrome.  See if you can post a picture.  There's a tutorial in General Discussion.  Welcome to ToolTalk!
« Last Edit: January 06, 2018, 06:00:30 PM by amecks »
« Reply #4 on: January 06, 2018, 06:14:40 PM »
Hello, Mark. Welcome to Tool Talk from Central New York. I took a picture of a wrench that I have here, is this the same hue as the finish on yours? I have not been able to determine what I have here, either. My photo skills aren't great, but I hope this helps. Regards, Lou
« Reply #5 on: January 06, 2018, 07:42:42 PM »
A warm welcome from cool Ohio.   A picture would help (not that i actually know anything).   :rolleyes:
Offline Markk
« Reply #6 on: January 06, 2018, 09:45:07 PM »
Yes, your wrench looks like mine; same color.  Looks like an old penny.
Trouble posting with my iPad; file too big.
« Reply #7 on: January 07, 2018, 07:59:03 AM »
I can't remember who it was but there was a company that did use a plating similar to that and described them as non sparking. I don't think the were offered for long before someone realized that once the plating was nicked all bets were off. Otherwise I would suspect that the nickel finish has been either worn or washed away by wear, chemicals, fire or some other means.
Offline RubiconJK
« Reply #8 on: January 07, 2018, 10:11:03 AM »
Here while back I was searching Alloy Artifacts for a similar finding on a Plomb wrench that was magnetic but appeared to be a copper color.  AA stated that Plomb (and I'm guessing others) sometimes used a copper undercoat over which they would apply nickel or chrome plating.  Could be your wrench has had the top coat worn off and it is the undercoat that is showing?
