1930's 1952 Ford
Started by OilyRascal, May 13, 2012, 05:36:03 PM
bgarrett
For driveshaft angle, set the base of the carburetor level with the ground, then whatever angle you have  at the tail shaft should match the angle on the yolk at the rear axle.
I have been driving a 1939 Ford pickup every day for 17 years thru four states usually pulling a trailer with an old car on it
OilyRascal
Quote from: Lump on May 14, 2012, 10:41:58 PM
There was also a 351 "M" series Ford engine, but that's yet another story.
I was thinking to myself there was a 3rd version, a Modified.  If you know it's story I'd appreciate a tid-bit.
1930
Thanks for all the tips, this old Ford was also avail. with a Vacuum assist on the rear end in 52 if I remember correctly, cant remember the model though.
The 351 I am using is a complete running engine so there will be no intake or nuthin to swap over. It is a Windsor by the way.
1930
Some of you guys might find this interesting, seems easy enough to understand. http://www.iedls.com/asp/admin/getFile.asp?RID=10&TID=28&FN=PDF
Papaw
Good stuff! Many rodders have no idea what they are doing.
