Author Topic: Solid Copper Block  (Read 3427 times)
Offline CraigC
Solid Copper Block
« on: October 01, 2013, 08:44:34 PM »
OK, it's not a tool, but I did find it with some old tools... :-)
Solid Copper Block
2 3/8" W x 2 1/4" H x 1 1/4" D
Scale reads:    0    20    50    OIL
Thx,
Craig
« Last Edit: October 01, 2013, 08:51:50 PM by Papaw »
Offline wrenchguy
    • Wrenchguys videos
Re: Solid Copper Block
« Reply #1 on: October 01, 2013, 10:27:18 PM »
a die 4 a oil pressure face?
« Reply #2 on: October 02, 2013, 09:45:50 AM »
for making a oil pressure gauge face?
Offline CraigC
« Reply #3 on: October 02, 2013, 01:08:14 PM »
>> A die for an oil pressure face?
I had thought about that, but wouldn't copper be too soft to act as a die?
If it is such, it would have to be the "master" template for a die since the block is not in reverse -- I know that's hard to see in my pix [sorry].
More info:  The block weighs about 2 1/2 pounds (40 to 42 ounces).
Thx for the fast responses.  Keep 'em coming!
Craig C
« Reply #4 on: October 02, 2013, 06:03:28 PM »
faces would be .020 or thinner many are done in Aluminum. That would raise the lettering then it would be highlighted with paint. could have been a test sample for the machine shop? but why in copper? The other part of the die could be rubber.
« Reply #5 on: October 02, 2013, 06:44:49 PM »
> but why in copper?
Because you can photo etch copper. That was the standard method or making a primary plate for decades for photolithography. (The copper plate then makes a consumable master, and the image is reversed in the process)
Offline superzstuff
« Reply #6 on: October 02, 2013, 08:15:53 PM »
I think it is half of a plastic mold.
