Is it a tool?
Started by harwill, May 17, 2013, 01:17:21 PM
harwill
Ok, 'nother whatsit:  This one is a 5/8 inch dia iron bar about 16" long.  It has been forged in the middle to create a rectangular hole about 3/8 x 1-1/8.  The ends are tapered, probably more so before someone re-purposed it to a double ended drift punch.  The exact center of the bar is marked through the center of the hole with a deep scribe line/chisel mark.  The whole thing appears to have been hand forged by a precision blacksmith!  See the pics for the other 1000 words...
"Sometimes I thinks Well..., and then again I don't know..."
Nolatoolguy
My first thought was for tap an die.
The more I think I wonder if it was for a blacksmith rod bending tool. Basically slides over the end of the stock he's twisting or bending an after stock is heated we're he chooses he turns the handles.
lazyassforge
Harwill, I am not sure but I think Nolatoolguy may be right about it being a tap handle. Look about halfway down the page on this thread:
http://www.papawswrench.com/vboard/index.php?topic=299.msg1697#msg1697
I posted a picture of an old blacksmith tap I have. I am not at home to measure it but it has a rectangular head which may be what fits into your handle!
Hope this helps, Bill D.
anglesmith
 I also think it is a tap wrench, According to trade pattern books rectangular ends on taps seemed to be generally common prior to about the 1850s, and they were two taps per set ( a tapered thread tap and a parallel tap)  Though top British engineers like Maudslay, Clements and Whitworth were using (modern!) three set square drive  (drop through) small shank taps as early as 1828 (English and American tool Builders By J W Roe)
Graeme
harwill
Well Y'all may be on to something here!  The taper on the ends may have been used to enlarge or even punch the starter hole for the tap in hot metal.  The sides of the rectangular hole with the score mark (not visible in the picture but vertical below the 8" mark on the tape measure),  has evidence of some wallowing that may have come from a tap...
If true, this could be from the 1800's?  Interesting notion.
Thanks all.
Harley
Dallas, Tx
johnsironsanctuary
Always remember that tools were not invented to do work. Work was invented so you could use tools.
Wrenchmensch
Always remember that tools were not invented to do work. Work was invented so you could use tools.[/color]
As I get older, the ability to resist editing another man's copy has weakened.  In place of the word use, how about design, as in "Work was invented so one could design tools to get it done more efficiently."
