Author Topic: Two layers, curved tip, layers spit to form two hexagonal openings  (Read 2814 times)
Offline restlessbee
Hi all,
First time here--I've got one that's driving me bonkers. Back in the fall, I purchased a lot of, I think, 8 of these off eBay. I found them browsing antique farm tools, but the seller didn't know what they were. They're forest green with plenty-o-rust. As far as I can tell, the part is two layers welded together. At the top half, the two layers are side-by-side, and they curve into a tip--not especially sharp, though whether that's by design or through age, who knows. Then, after two circular holes, the layers split apart to form two sides. At the bottom of each is a hexagonal opening, 1" across. There's about 1/2" space between the layers.
Anyone have any ideas? I'm far from an expert and am usually content to guess at tool purposes, but this one has me flummoxed.
Thanks very much!
Erik
Offline international3414
Re: Two layers, curved tip, layers spit to form two hexagonal openings
« Reply #1 on: February 10, 2014, 07:47:31 PM »
a part of something,not a tool....WAG
« Reply #2 on: February 10, 2014, 08:24:44 PM »
I agree. Part of something. Perhaps a latch?
By the way, welcome to Tool Talk!
« Reply #3 on: February 10, 2014, 08:40:38 PM »
 My guess would be a ground engaging tool maybe from a garden cultivator. The hex could mount on shaft to prevent turning but don't see usage of cross drilled holes.
« Reply #4 on: February 10, 2014, 08:46:58 PM »
That led me to guess they might be harrow teeth that are on a hexagonal shaft and the holes could be for springs to keep them in position.
Like these-
Offline restlessbee
« Reply #5 on: February 11, 2014, 11:06:50 AM »
Thanks, all--for the welcome and for the leads. I have several new keywords to add to my search repertoire now--I'll definitely follow up if I'm able to ID the part definitively.
« Reply #6 on: February 11, 2014, 04:35:43 PM »
John Deere green?
Offline restlessbee
« Reply #7 on: February 11, 2014, 07:34:07 PM »
Rusty, I had the same thought, but thought the green was too dark. Well, I'm a little bit slow sometimes. After a good scrubbing with dish soap and a sander sponge, sure is looking more Deere-greeny.
Offline strik9
« Reply #8 on: February 13, 2014, 12:11:15 AM »
  Oliver or Hart-Parr green possibly?    JD was always lighter toned.
