Author Topic: Small tubing bender?  (Read 1883 times)
Offline Edkat3
« on: February 16, 2014, 08:12:32 PM »
Found this the other day. made by the Newton Mfg. Co. Plainfield, CT. Looks like a small tubing shaper are something to do with wire or small rope. Any idea??
Re: Small tubing bender?
« Reply #1 on: February 17, 2014, 03:12:34 AM »
For hydraulic brake pipes??
« Reply #2 on: February 17, 2014, 04:26:31 AM »
I don't think it is a pipe or tube bender.  By the way the straight leg is reinforced, I am guessing it is pushing against something while the bent leg holds on.
My guess is some kind of wrench for a union lug nut of some kind.
« Reply #3 on: February 21, 2014, 03:49:59 AM »
Could it be a front-end alignment tool?
« Reply #4 on: February 21, 2014, 08:58:17 AM »
I'll guess it's for a packing nut , inside a tube.
« Reply #5 on: February 27, 2014, 06:36:45 AM »
Just found an image of s similar tool - used to tighten loosen a DSP type hose connector,
see: http://en.wikipedia.org/wiki/DSP_coupling
another possible answer, or at least a similar usage....????
« Last Edit: February 27, 2014, 06:38:35 AM by Billman49 »
