Author Topic: What's this tool for?  (Read 2970 times)
Offline tbruce
« on: February 19, 2014, 06:31:39 PM »
Can anyone tell me what this tool is used for?
Offline tbruce
Re: What's this tool for?
« Reply #1 on: February 19, 2014, 06:32:26 PM »
here is another angle
« Reply #2 on: February 19, 2014, 06:53:06 PM »
I think it used to be a can opener. The plated screws seem inconsistent with the rest of the tool...
« Reply #3 on: February 19, 2014, 09:00:49 PM »
I agree.
« Reply #4 on: February 20, 2014, 01:21:20 AM »
Did you know the can was invented before the opener? (~48 years) So how did they open cans? check out "How to open cans without tools"  best I seen was to rub it on concrete to thin the rim & squeeze to open.
« Last Edit: February 20, 2014, 01:30:33 AM by oldtools »
« Reply #5 on: February 20, 2014, 11:02:01 AM »
It looks like it may be a Stillman's patent saw set, that someone converted to an opener.  Look on the shank just above the ferrule for the Stillman and the 1848 (I think) patent date; sometimes they are not there or are faint.
« Last Edit: February 20, 2014, 11:03:33 AM by wvtools »
Online Lewill2
« Reply #6 on: February 20, 2014, 11:54:30 AM »
WV I thought that too at first but after I enlarged the pictures I don't believe it started life as a Stillman.
« Reply #7 on: February 21, 2014, 11:13:34 AM »
Undo the wing nut and turn the blade through 90 degrees - the two (new replacment) lock screws allow the distance between the handle and the blade to be adjusted... I reckon in this arrangement it will work as a saw set....
It certainly looks like a Stillman's type ...
This one has a similar triangular adjustable (single ended) blade
« Last Edit: February 21, 2014, 05:26:56 PM by Billman49 »
Offline dowdstools
« Reply #8 on: February 21, 2014, 07:42:18 PM »
Yep, it's a saw set.
Lynn
Online Lewill2
« Reply #9 on: February 22, 2014, 05:48:01 PM »
My Stillman saw set, with the star wheel for different thickness saw tooth configurations.
