Author Topic: 2 unknowns  (Read 3758 times)
Offline swervncarz
2 unknowns
« on: May 05, 2014, 04:33:33 PM »
Picked these 2 out of the same lot. They seem to be similar, I'm guessing that they are for the same thing. Can anyone tell me what they are called & used for?
Re: 2 unknowns
« Reply #1 on: May 05, 2014, 04:55:02 PM »
Punches for leather or belting, I believe.  Or just making leather discs, in the case of the larger one.
Re: 2 unknowns
« Reply #2 on: May 05, 2014, 04:56:14 PM »
I think john is correct.
I would also go with leather working.
Offline international3414
Re: 2 unknowns
« Reply #3 on: May 05, 2014, 05:12:55 PM »
they call  the larger one a arch punch
Re: 2 unknowns
« Reply #4 on: May 05, 2014, 06:11:22 PM »
The large one is unusually rugged for that pattern....
Almost, but not quite looks blacksmith made..
Re: 2 unknowns
« Reply #5 on: May 05, 2014, 07:56:03 PM »
Not just leather, but other materials also.  On full face flange gaskets you use one like those to cut the bolt holes.
I have a black rubber pad about 3/8" thick.  Put whatever material I want on top of the pad, then punch through it.  Cuts material like cloth, paper,  etc.
Re: 2 unknowns
« Reply #6 on: May 05, 2014, 09:48:58 PM »
I'm not clear on the original intended use but as Chilly has stated, they were used for purposes other than leather.  It is this common place here for the oil well service folks to have a variety.  I've seen my grandfather, and father alike, use them for cutting gaskets.  But on the other hand, I have also seen them use a very small ball pein hammer alone to cut whatever gasket was needed.
Re: 2 unknowns
« Reply #7 on: May 05, 2014, 10:07:02 PM »
The larger one is often called an arch punch in the old catalogs.  As mentioned above, they were advertised as punches to cut leather, rubber, paper, and other materials.  Brands that I typically see include Osborne, Johnson, and Kraueter.  Several companies would make custom shape arch punches.
EDIT:  Sorry International3414, I did not see your post.
« Last Edit: May 06, 2014, 11:36:35 AM by wvtools »
Re: 2 unknowns
« Reply #8 on: May 06, 2014, 02:47:27 AM »
Known in the UK as wad punches, originally made to cut wads used to seal the bore of muzzzle loading rifles etc - but later many more uses, e.g. cutting holes in sheet material such as leather or card... My friend uses them to cut pads used to seal the round holes in concertinas - what in other uses is the waste is the product he requires (much closer to the original use). He also uses those with other shaped holes, e.g. oval(ish) to produce small valves (seals used to cover the back of the reed hole)..
« Last Edit: May 09, 2014, 02:08:15 AM by Billman49 »
Offline BruceS
Re: 2 unknowns
« Reply #9 on: May 07, 2014, 07:00:20 PM »
I retired out of an Electric Power House and we used them for punching the bolt holes in gaskets.
Re: 2 unknowns
« Reply #10 on: May 07, 2014, 11:12:08 PM »
Rubber works good as a backer, if you have scrap rubber.
  If not, just grab a handy block of scrap wood.
 Place the wood in your vise with the --end-- grain up.
  End grain rocks with arc punches! And you can always find or cut off a scrap.
Offline BruceS
Re: 2 unknowns
« Reply #11 on: May 08, 2014, 07:36:57 PM »
Our shop actually had a 30" diameter log X 36" long standing on a butt end that was uses for use with those punches.
