I have found your site while searching for more information about an old bed wrench or key my Dad bought me years ago. While there is a mark punched on the tool, some letters are difficult to make out, plus several are missing where there is a small scooped out place in the metal – which was probably there before the name was punched over the top. It appears to read R. Wit ???lind & Sons.The tool was bought in an antique shop in New Zealand, which is where I live.I am afraid I do not know enough about metal working to tell you if the tool is hand forged or moulded (we add that “u” here in New Zealand!). There are what I would call “chisel” cuts, approx quarter inch long or slightly less, in the four corners of the central slot, both front & back, as if the maker hand cut out the slot, plus, between the cuts, a very small “scoop” of iron has been removed, front & back. NB: It is the “scoop” on the topside of the tool that obscures the letters. Are you able to identify the maker, or suggest somewhere else I could look to find out?
Well, one of my clever sons, being a whiz with the internet search engines, found the exact tool online, and was able to read the manufacturer: R. Timmins & Sons, Birmingham, England. Further sleuth work may reveal a possible date of manufacture. Attached are two views of it. Each of the three ends has a similar socket (?) for undoing bolts/nuts. With kind regards Barbara Rhodes
It is the 18th century version of the cheap stamped steel wrench you get with build it yourself furniture in a box...>Kinda like a chastity belt for a bed?That would require a wench key.
