Author Topic: 12" Westcott/Pipe Wrench  (Read 3318 times)
« on: July 13, 2014, 01:38:39 PM »
Finally ran on to one of these, its pretty worn and needs work but the price was right.
Re: 12" Westcott/Pipe Wrench
« Reply #1 on: July 13, 2014, 07:32:33 PM »
Found one myself a couple years ago as I was walking across the pasture at my gpa's place.  Talk about rough shape.
« Reply #2 on: July 15, 2014, 06:02:21 PM »
Nice big one!
« Reply #3 on: July 15, 2014, 09:13:05 PM »
Nice! I take it they made a "12 NUT" version also??
Offline Bus
    • The Wrenchingnews
« Reply #4 on: July 15, 2014, 10:08:23 PM »
Yes in several sizes. they are more common then the pipe jaws variety.
« Reply #5 on: July 15, 2014, 11:02:22 PM »
The nut wrench versions are marked "8 Inch, 12 Inch" etc.  The "PIPE" marking only appears on the version where the "fixed" jaw is at an angle and has pipe gripping teeth.  They also made a version where the pipe grip was on the movable jaw so that you could use one handle  for interchangeable pipe and nut jaws.  As "Bus" noted, all the pipe wrench types are scarcer than the nut wrenches.
« Reply #6 on: July 16, 2014, 03:41:03 PM »
Thanks for the info fellas! Sounds like HeelSpur's find is even more special than I thought it was.
Offline international3414
« Reply #7 on: July 16, 2014, 05:06:36 PM »
didnt these have a replaceable jaw insert,looks to be missing on this one??
« Reply #8 on: July 18, 2014, 11:50:52 PM »
On the ones with replaceable jaw insert, the interface between the hard steel pipe gripping teeth insert & the wrench body is relatively "wavy" and there is a good size hole for the screw that holds the insert in place.   This one just has well worn pipe gripping teeth that are integral with the wrench body.  (I have "sniped" photos from long-ago eBay lots showing 6", 8" & 12" WESTCOTT Pipe wrenches with the hard steel jaw inserts.)
