Author Topic: Masonry tool?  (Read 3019 times)
Offline toolmiser
Masonry tool?
« on: August 11, 2014, 07:54:51 PM »
I picked this up at a garage sale because it was a tool, and I had no idea what it's for.  The text on is reads:  TARGET Masonry saws-blades  Kansas City 10, Missouri.  It may be a promotional item.  Could it be for setting angles on a masonry saw for cutting block or brick?  All comments appreciated.  I have $2.00 tied up in this.
Offline pritch
Re: Masonry tool?
« Reply #1 on: August 11, 2014, 10:44:55 PM »
It's a guide that hooks to the table on a masonry saw, for cutting angles on brick or block. How big is it? It looks kinda small for a commercial saw.
Offline toolmiser
Re: Masonry tool?
« Reply #2 on: August 12, 2014, 06:29:47 AM »
It's 6 3/4" long, sorry I should have put a visual marker in the picture.  What is the point of the thumbscrew?
Thanks!
Re: Masonry tool?
« Reply #3 on: August 12, 2014, 07:09:02 AM »
Looks to me as if it would clamp onto the back of a hand saw type of stone saw, to enable the user to gauge the angle by eye...
My TCT tipped saw has a blade about 1/8" (3mm) thick - much thicker than the equivalent wood hand saw...
Re: Masonry tool?
« Reply #4 on: August 12, 2014, 01:59:34 PM »
Thanks!
If Pritch is right, and I think he is, then the thumbscrew tightens against the lip on the front of a masonry saw table.  Those saws have either sliding tables or the saw cuts through like a sliding chop saw.  The lip on that table is where the guide attaches. The set screw keeps the guide in place.
« Last Edit: August 13, 2014, 06:52:38 AM by Chillylulu »
Re: Masonry tool?
« Reply #5 on: August 12, 2014, 04:03:32 PM »
Here's a slightly different one in place, clamped to the front of the saw table....
Offline toolmiser
Re: Masonry tool?
« Reply #6 on: August 12, 2014, 04:16:04 PM »
Nothing like a good visual to get the point across.   It makes real good sense now.  Thanks again!
