Bulk pick-up time, free stuff dumped..
Started by oldtools, August 17, 2014, 02:35:51 AM
oldtools
Bulk pick-up time again, Just picked free stuff people dumped.. Old Sears Roebuck 900W alternator 115V 7.8A, 16-1 oil mix.
Spark & compression OK. checking carburetor tomorrow, then try to start...  anyone know about this model?  Age, parts? etc..
eddie hudson
#1
580 = GENERAC CORP
bonneyman
I picked up a lawn mower for free, owner said it stopped running a few years ago. Cleaned out the gas tank, and the carb, filled and it started right up.
It just baffles me what people throw away. That little unit you got there would be just perfect for a power outtage situation, at least keep the reefer going.
rusty
I would expect goo in the carb, but won't be surprised if that's all that is wrong with it, it is a fairly simple machine. Just be carefull about plugging electronics into it, the older small generators with permenant magnet rotors have no voltage regulation and are a little hard on newer electronics...
(Probably too small for the fridge, won't be able to start it)
Bill Houghton
Quote from: rusty on August 17, 2014, 09:56:19 PM
Which is a problem with modern appliances, many of which have electronic components.  Our refrigerator, for instance, is run entirely by a circuit board that the manufacturer cleverly put in the fridge compartment, where it could get affected by moisture.
EVILDR235
I am glad someone like you found it. It could have wound being scrapped for the copper in it. I have started buying up small old engines Like Briggs and Stratton, Kohler, Clinton, lauson, Tecumseh and so on. These little engines from the 40s, 50s, 60s are little gems and worth saving.
oldtools
Yep! 900W is OK for lights, etc. maybe small frig. but only rated Max 7.8A,  didn't get a chance to check the carburetor yet, but sounds like it wants to start, but no gas. will let you know when I get it started...
turnnut
Chillylulu
Quote from: oldtools on August 18, 2014, 03:47:21 PM
Not an electrician, but here goes...
900 w /115 volts = 7.82608  amps
The problem is the rated voltage is produced at a certain RPM. If the engine speeds up or down your voltage changes too.  Older engines would rarely have governor's for protecting against higher voltage / current.
When you adjust it - check the output voltage.  Better yet - use it as one of many power sources for charging batteries. Use them to provide your clean power.
