Author Topic: I got cheated  (Read 2719 times)
I got cheated
« on: January 15, 2015, 01:40:28 PM »
 Bought a Walworth pipe wrench today. It is clearly marked 48 in but its only 42 1/2 in long. I guess I could screw the jaw out a little and make it 48 in. It weighs 29 1/2 lbs. Have zero use for it but fellow auction goer said (I saw the look in your eye and knew you were going to buy it) Guess I could make a mail box post out of it.
Re: I got cheated
« Reply #1 on: January 15, 2015, 01:57:26 PM »
Cool wrench! It would have come home with me too...
Re: I got cheated
« Reply #2 on: January 15, 2015, 03:43:03 PM »
You got the rare compact 48.
Re: I got cheated
« Reply #3 on: January 15, 2015, 05:04:42 PM »
Sounds like something you would read on a overpriced craigslist add.
Re: I got cheated
« Reply #4 on: January 15, 2015, 09:38:18 PM »
sounds like some of us older folks, gets shorter with age.
I would also be the person carrying it out to my truck.
would make "one heck-of-a-door-knocker."
weld it to a steel post and hang plants on it.
Re: I got cheated
« Reply #5 on: January 16, 2015, 12:18:40 AM »
While they are  here & readily available I'll copy a photo or two & update the DATAMP entry for the patent.
The handle is proportionally slim relative  to the head when you  compare it to the 8" size.
Re: I got cheated
« Reply #6 on: January 16, 2015, 02:18:11 AM »
Sounds like they used the same method as big screen tv's.
That wasn't a 48" wrench, it was a 48" class wrench.
Re: I got cheated
« Reply #7 on: January 16, 2015, 05:29:35 AM »
Begs the question:  What is the method, from a engineering/design perspective, of measurements?  With flat screens, I have been told they are measured diagonally from corner to corner (the larger measurement).
Re: I got cheated
« Reply #8 on: January 16, 2015, 08:34:57 AM »
True enough, but now there are "classes" too.
Viewing area should be within 2" +/- of the class size. The term "class" reflects the fact that screens have different size bezels.
PS: Class size still isn't enough to explain your 3.5" shortfall.  In the dirty part of my mind I keep assuming the wrench length was made by the same person whose wife has been told that 4" is actually 6" for so long that she believes it.
