Author Topic: Some type of tin cutter???  (Read 5126 times)
Offline bigslicktux
« on: July 21, 2015, 07:20:43 PM »
My great uncle had this in his shop. I'm not sure what its purpose is. I'm thinking it cuts slots in tin. Your help is appreciated. Thanks.
Offline Bus
    • The Wrenchingnews
Re: Some type of tin cutter???
« Reply #1 on: July 21, 2015, 08:14:23 PM »
Looks kinda like a stove pipe crimper but I have never seen another one like it?
« Reply #2 on: July 21, 2015, 08:25:05 PM »
don't look like it can cut?
the step teeth going the wrong way for a stove pipe crimper.
might be a crimper for banding / strap iron?
« Reply #3 on: July 21, 2015, 08:46:15 PM »
I also was thinking steel banding sleeve crimper.
the grooves would make the sleeve harder to slide loose.
« Reply #4 on: July 22, 2015, 06:00:53 PM »
I don't think it's for cutting either.
My best guess would be some sort of crimping tool.
Offline bigslicktux
« Reply #5 on: July 22, 2015, 06:49:58 PM »
Thanks for the replies everyone. The reason I think it's for cutting is the teeth move all the way through that opening.
« Reply #6 on: July 22, 2015, 09:26:03 PM »
is there any name or numbers on that tool ?
« Reply #7 on: July 22, 2015, 10:13:24 PM »
Gotta be a nut cracker.
« Reply #8 on: July 23, 2015, 01:38:01 AM »
What are the general dimensions, and what's the clearance on the side of the blade to the socket as the tool is closed?
« Reply #9 on: July 23, 2015, 06:25:19 PM »
did you test it on some sheet metal? does it cut or crimp?
Offline anglesmith
« Reply #10 on: July 24, 2015, 01:32:40 AM »
I believe it is a medical instrument for cutting plaster casts.http://www.medezine.co.uk/product-range/stille-cast-shear/
Graeme
Offline bigslicktux
« Reply #11 on: July 24, 2015, 06:00:48 AM »
Sorry it took so long to get back to you. Thanks again everyone. I would say it's roughly 2 feet long and there is no clearance.  No, I have not tried cutting any sheet metal. WOW! That cast cutting tool has to be it. It's identical.  I have no idea why that would be in his shop. LOL!
Offline bigslicktux
« Reply #12 on: July 27, 2015, 12:20:11 PM »
Just bumping the post again. This is not a cast cutting tool. Even though it looks identical. I have noticed upon closer review of the pictures of the cast cutting tool that it has more of a blade jaw. This tool looks more like it punches these slots out of it. Any more thoughts?
Offline anglesmith
« Reply #13 on: July 27, 2015, 10:55:48 PM »
bigslicktux, I still think it is a plaster cutter. Finish and style definitely put in the medical instrument field, this type of cutter has probably been made for a 100 plus years by a large number of medical instrument makers so exact details and ideas would have varied greatly. I have very large number of trade tool catalogues and nothing like your tool is to be found in them.  Here is a scan from the ONE medical catalogue that I have!?
Graeme
« Last Edit: July 27, 2015, 11:04:01 PM by anglesmith »
Offline PFSchaffner
    • VintageMachinery profile
« Reply #14 on: July 28, 2015, 08:34:03 AM »
I for one am convinced by the medical interpretation. It is clearly a 'nibbler' of some kind, and the teeth suggest that it is designed to nibble through something crunchy and friable (like plaster) rather than something that cuts cleanly (like sheet metal).  I do find myself wishing I had more medical device catalogs, however: I've desired them ever since I had to catalog a set of Civil-War-era surgical instruments 20 years ago, but they tend to be quite pricey. GoogleBooks/HathiTrust have come through with a few over the past few years, which helps.
pfs
member: TATHS | MWTCA | EAIA | MVWC | CRAFTS
tool-cleaner and -sorter, Ann Arbor Kiwanis Thrift Sale
