Author Topic: A Whats-it and Whose-it?  (Read 3417 times)
Offline lebaron
« on: September 01, 2015, 01:11:36 PM »
Has no name just numbers. Appears to be very well made.
Re: A Whats-it and Whose-it?
« Reply #1 on: September 01, 2015, 03:54:45 PM »
Looks task specific.  Completely outside of my narrow realm of experience.
« Reply #2 on: September 01, 2015, 08:46:36 PM »
No idea, but I note they have wire cutters; so whatever trade they were used in used wire.
« Reply #3 on: September 01, 2015, 10:19:56 PM »
I kind of wonder if they are some kind if crimper, like a seal crimper?!?
« Reply #4 on: September 03, 2015, 10:30:44 AM »
Seal crimper is a good guess.  The tip for twisting wire, the flat part in the middle for squashing a lead seal, and cutters for the extra wire.
Lead seal crimpers (if that is what these are) were used on diesel fuel injection pumps, carburetors and other equipment where the manufacturer did not unauthorized adjustments made.
« Last Edit: September 03, 2015, 10:56:01 AM by amecks »
« Reply #5 on: September 03, 2015, 12:12:58 PM »
+1
« Reply #6 on: September 03, 2015, 02:01:12 PM »
And on utility meters to prevent tampering. Gas and electrical.
XXXXXX
Offline k9gl
« Reply #7 on: September 08, 2015, 08:18:24 AM »
It's Military, and used for aviation.  The 68D33277 shows as a Pliers originally added in 1968.  The description is "PLIERS ASSEMBLY,ARMING WIRE CLIP"
Offline lebaron
« Reply #8 on: September 09, 2015, 08:53:18 PM »
Thanks great job. Here's the link http://www.asap-aerospace.com/rfq/ogden-air-logistics-center/5120001166136/68d33277/  I guess these will be one of my big sellers. Every house should have one. Thanks everyone for trying to figure it out.
Offline RWalters
« Reply #9 on: September 09, 2015, 10:42:10 PM »
I picked up a couple of arming wires, still mounted on a piece of cardboard with identifying information, at a garage sale a while back. I did a little research to find out what they were and learned that they attach to the fuze of a bomb and prevent the fuze from arming until the bomb drops away from the aircraft. They use spring clips called Fahnestock clips to retain the wire in position and those clips may be what these pliers were used on. If you Google "bomb arming wire Fahnestock clips" you'll see lots of images of how the wire and clips were used.
« Reply #10 on: September 10, 2015, 05:19:12 AM »
Neat!
« Reply #11 on: September 10, 2015, 10:41:50 AM »
If they don't sell, you might look around for one of the air museums that has WWII planes, and see if they'd like them.
