Author Topic: Got 2 smallish odd looking What is it?  (Read 6452 times)
Re: Got 2 smallish odd looking What is it?
« Reply #15 on: December 14, 2015, 11:26:00 AM »
Maybe its for reeming down the end of a dowell rod.
« Reply #16 on: December 14, 2015, 11:58:19 AM »
not sharp any where? the ovalish one has a better in side.
« Reply #17 on: December 14, 2015, 01:47:40 PM »
OG you forgot to use Crisco to lube the device.
Nice color clay though.
« Reply #18 on: December 14, 2015, 04:04:19 PM »
The clay has some mineral oil on it so it came out easy.
I was thinking of you all here with the colour!
For free I got 40-50 of unopened, another 40-50 of open stuff.
And of course I had just bought the big block sculpty clay.
« Reply #19 on: December 14, 2015, 04:45:15 PM »
OK, you ram about half an inch of sculpting into the coal forge pan for a liner, and go all class with a nice white glaze for maximum IR reflection.
How much slip have you got in inventory?
« Reply #20 on: December 14, 2015, 06:04:57 PM »
slip?
Icabod Slipp? 3 Stooges short  Hold that Lion?
« Reply #21 on: December 14, 2015, 09:13:26 PM »
NO.  Slip as in the white clay you mix up to be about like a milkshake in a cheap choke & puke, pour into a plaster mold and then empty most of back into the jug.
That slip clay.
« Reply #22 on: December 15, 2015, 09:10:11 AM »
I'm not a potter, but I should have known that.
Offline JoeCB
« Reply #23 on: December 23, 2015, 11:01:28 PM »
just a guess.... gem stone cutters set the stones in hard wax to hold them for grinding the facets and polishing....could be a handle for that trade
Joe
« Reply #24 on: December 29, 2015, 04:00:17 AM »
Joe
When cutting cabs you usually use a wood dowel. There is a commercial dop stick, but it is aluminum, with a flared end.  None have handles, but they would be nice often.
Small metal dops are used for faceting stones. Commonly,  they have ends that are flat, conically cut in from the end, and "V" shaped notches in the end. Other end configurations are less common.  A handle would get in the way when mounting the dop to the grinding jig.
I've cut lots of cabs, but I haven't cut any faceted stones. I have 3 or 4 cabbing grinders.
