Does it have to be a scissors-type expander? I've successfully expanded components a piece of threaded rod or long bolts (threaded full length), a nut or three, and a piece of pipe sized to slip over the rod/bolt. If you use threaded rod, you need three nuts, two to lock against each other and hold the rod still while you turn the nut against the pipe to push it along the rod, expanding the whole assembly.
