Author Topic: Number 11 but what does it do?  (Read 2958 times)
« on: January 08, 2016, 11:53:31 AM »
no clues here  just says  No11
cuts? crimps? folds?  goes fishin?
AJAN 209 by Skip Albright, on Flickr
AJAN 213 by Skip Albright, on Flickr
Re: Number 11 but what does it do?
« Reply #1 on: January 08, 2016, 06:24:26 PM »
wag , seam maker for tin
« Reply #2 on: January 08, 2016, 06:57:23 PM »
Hello, Skipskip. Maybe a tobacco cutter? I see you are in New York State, I live upstate, Syracuse, to be exact.Regards, Lou
« Reply #3 on: January 08, 2016, 07:42:46 PM »
someone suggested for crimping the end of a toothpaste tube, the metal ones we remember
« Reply #4 on: January 08, 2016, 07:43:51 PM »
Albany Lou, not too far. for the folks in Texas, it's just across town
« Reply #5 on: January 09, 2016, 08:44:40 PM »
someone suggested for crimping the end of a toothpaste tube, the metal ones we remember, if we're more than 60 years old.
Fixed it for ya.  I could be off a year or so on the age, but not by much.
I used to cut those metal toothpaste tubes up and roll them up for fishing weights.
« Reply #6 on: January 09, 2016, 08:51:26 PM »
Skipskip,  looking at your 3 or 4 pictures, a few things that I noticed was (1) on the round grooved disc wheel, it's stamped "OIL",
that would make me look away from tobacco or food products.
(2) below the grooved disc/wheel ? looks like an anvil that is adjustable up & down by way of loosening the 2 square headed screws
below the anvil.
(3) when you pull the lever, does the cogs make the disc/wheel slide back & forth ??
mounted on a board, it could be a once in a while needed tool ??? 1 hole in the board could be to hang it on the wall near a bench.
used like for perhaps straightening something like copper tubing ?
not being able to touch this tool, this is just my off the wall observations.
« Reply #7 on: January 10, 2016, 06:41:01 AM »
What is the size of the groove?  Could it be a burnisher for round leather drive belts for sewing machines and lathes?
« Reply #8 on: January 10, 2016, 01:03:19 PM »
If you click on the picture it takes you to Skip's Flickr page. You can see additional pictures there. I can't tell from the pictures if you can place a sheet under the wheel and it will fit under the rack gear that the handle engages. I'm thinking a sheet metal shear for slitting a sheet or strip for fabrication. I don't understand what the hex head fasteners are for out board of the square head set screws that lock the anvil in position.
« Reply #9 on: January 10, 2016, 02:32:10 PM »
 my thought on the hex head bolts was to raise or lower the ? avil/plate ???   for different size ?? whatever is being drven thru ???
« Reply #10 on: January 10, 2016, 04:43:43 PM »
not a cutting tool (worth a damn) would only would cut the width of the casting cause of the gear.
some type on straight 4" long thing-a-bob tool I've looked thru Pexto & Niagara s/m tools, not there.
