Author Topic: Journeyman bench grinder  (Read 3078 times)
Offline Jimibab
« on: February 09, 2016, 05:19:08 PM »
Found this at my local second hand store for $10. I've found similar looking models but nothing specific to this make. What specs should I be looking for to frankenstein this back together?
Re: Journeyman bench grinder
« Reply #1 on: February 09, 2016, 05:35:13 PM »
If it runs, what else do you need besides the diameter of the shaft so you can buy the right size wheels? But wheels that match the stated RPMs of the motor.
Offline Jimibab
« Reply #2 on: February 09, 2016, 09:43:55 PM »
The guards and flanges, but if shaft diameter is the primary concern, I can make other pieces fit. Thanks for the feedback
« Reply #3 on: February 09, 2016, 10:04:15 PM »
I wouldn't be surprised if other Taiwanese and/or Chinese units are the same. Probably a lot of units were made to be branded by marketers.
« Reply #4 on: February 10, 2016, 02:09:12 PM »
Run it before you spend time on it.  Many, though not all, of the Taiwanese grinders would serve better as the power source for those magic fingers vibrating beds.  I briefly owned one that, with a long enough power cord, could have walked itself all the way to Peoria.
« Reply #5 on: February 10, 2016, 07:34:52 PM »
 it may not have had any guards, it might have been a buffer.
Offline Jimibab
« Reply #6 on: February 11, 2016, 10:11:55 PM »
Bill - It runs just fine. I tested it before I bought it. Though I do so enjoy those beds...
Turnnut - It's got tapped holes where the guards would have been. Maybe the previous owner used it as a buffer and tossed em.
« Reply #7 on: February 11, 2016, 10:56:48 PM »
Many motors with double shafts were sold as multi use replacement motors. I have several dual shaft motors that were on table saws that i bought. One was on a band saw and another on a jointer. Several are Sears branded and several Wards branded.
XXXXXX
Offline Jimibab
« Reply #8 on: February 12, 2016, 04:49:38 PM »
Well, then, I'll just get creative and see what I can make this thing do.
« Reply #9 on: February 12, 2016, 08:05:59 PM »
 I'd say 1/2 hp is kinda light for a grinder but it'll probably work real well as a buffer.
Offline Jimibab
« Reply #10 on: February 12, 2016, 09:05:36 PM »
I'm thinking about converting it into a belt sander
