Author Topic: Picked up some neat ones this weekend need a little help  (Read 5417 times)
Offline blackoak
« on: May 02, 2016, 07:47:01 PM »
Got this bunch at a local auction. I know what most of them are and what they are for except the large T shaped item and the Big wrench. What was the wrench made for? It is marked Fairmont Cleve. The large T shaped item was forged welded together and is very hard. It had a sharp tapered end on one side and a sharp cutting edge on the other with the bottom part that triangles down to a sharp point. It makes the nicest ting when tapped with a hammer. I have no idea what it was made to do. Cut, chop something I assume. It is marked as the one picture will show. The one S shaped wrench is marked reverse gear wrench. Don't know what it was used for either. The one wrench is a John Deere wrench. I got a nice KD nut cracker in the deal. I know what the cone shaped item is and what it went on. Anybody else know? The nut driver is a Vlchek 1/2" nut driver.   And last a duel hog wringer with an 1883 pat date. Not a bad deal at 20 bucks for the lot.
« Last Edit: May 02, 2016, 07:51:47 PM by blackoak »
Offline strik9
Re: Picked up some neat ones this weekend need a little help
« Reply #1 on: May 02, 2016, 07:55:32 PM »
The reverse gear wrench is designed for adjusting the reverse gear brake band in a Ford T transmission.
   Relatively common in good condition.   I have one also.
« Reply #2 on: May 02, 2016, 09:17:50 PM »
the large t-shape item looks like a roof slaters anvil.
to the left of it, is that a corn nubber ???
« Reply #3 on: May 02, 2016, 10:15:40 PM »
I spy a Vlchek nutdriver there, a smallish one.
Offline humber2
« Reply #4 on: May 03, 2016, 03:30:26 AM »
There were several makers of the large wrench.
I believe it fits hub caps on a pre 30 Studebaker.
« Reply #5 on: May 03, 2016, 06:03:44 AM »
I believe the large "T" shaped item is an early twibil used to clean up mortises.
« Reply #6 on: May 03, 2016, 06:44:48 AM »
I think Lewill is right about the twibill/twybil.  Slater's rooof anvils are not sharp on the ends, although without a handle, the twybil does really resemble it.  The twybil is one tool that I have never owned in 25 years of dealing in tools.
Offline Twertsy
« Reply #7 on: May 03, 2016, 06:50:42 AM »
Yup, I have one resting in it's spot on my Bonney Display Board from ca. 1920.
Offline blackoak
« Reply #8 on: May 03, 2016, 07:06:14 AM »
Yep,  that is a nubber off an old hand crank corn sheller. Some had them and some didn't. It was designed to remove the corn on the very tip of the cob.
« Reply #10 on: May 03, 2016, 10:03:29 AM »
 I stand to be corrected, I agree with it being a twybill, pardon my spelling.
« Reply #11 on: May 03, 2016, 12:45:38 PM »
Sellens lists the spelling both ways.  That is why I just put in the alternate spelling, but did not correct you.  I would guess that twybil is an older form of the spelling than twibil.
Offline RWalters
« Reply #12 on: May 05, 2016, 11:30:08 PM »
Regarding the twybil, the mark stamped on it looks very much like the broad arrow used in Great Britain to mark items (including tools) that are government property.
« Reply #13 on: May 06, 2016, 11:41:13 AM »
So we may have evidence of not just a tool heist but an international tool heist?
Offline blackoak
« Reply #14 on: May 06, 2016, 12:05:27 PM »
You saying the Queens coming for me. I better ditch the evidence fast. LOL :smiley:
