Author Topic: Clamps? Crimper? Piano Tuning?  (Read 3091 times)
« on: July 22, 2016, 07:44:11 AM »
Hello, All. At the top is what I am guessing to be some sort of lineman's tool/clamp? Next is a pliers, closes to 5/16" hole, re-loading? sinkers?. Next is a rosewood handle, with an 8-jaw chuck, Piano Tuning Hammer/Wrench handle?( I have only seen fixed versions). Next is some sort of pick-up tool, very well made and does not close all the way. Last is some sort of adjustable clamp? All but the lineman's clamp came from same owner, from what I gathered, he did watch repair, radio repair, among many other interests. Thanks, Lou
Re: Clamps? Crimper? Piano Tuning?
« Reply #1 on: July 22, 2016, 09:24:45 AM »
The little gripper/pick up tool reminds me of a sugar cube pick up tool I have seen advertised in the past. To pick up a cube of sugar for your cup of tea.
« Reply #2 on: July 22, 2016, 11:04:29 AM »
Heres a similar gripper that I had tagged as patented ice cube tongs. No patent number on tongs and I don't remember how I found patent. Seems like I had a second slightly different tong that I identified as sugar tongs. Let someone talk me out of the sugar tongs so can't compare.
« Reply #3 on: July 22, 2016, 11:16:21 AM »
Hello, I did a little checking, most of the ones used for sugar were 3-prong. I believe they are also referred to as sugar cube tongs, sugar cube claws, or sugar cube pincers. Thanks, Lou
« Reply #4 on: July 22, 2016, 11:37:45 AM »
The wood handled thing looks like a pin vise. Does that hole that goes all the way thru the handle?
« Reply #5 on: July 22, 2016, 01:09:51 PM »
Kind of a big hole for a pin vise.  I assumed it was one of those handles for various tools, missing the tools.
« Reply #6 on: July 22, 2016, 02:37:16 PM »
You may be right. Pin vise was the first thing that came to me. It could also be a needle file handle.
« Reply #7 on: July 22, 2016, 02:38:19 PM »
How big is the hole in the jaws? Marking chalk holder or marking crayon holder?
« Reply #8 on: July 22, 2016, 02:46:14 PM »
Could also be missing a collet that goes in that hole.
Offline kwoswalt99
« Reply #9 on: July 22, 2016, 03:40:21 PM »
If it was mine, I would make some cutting tips and use it as a detachable lathe tool handle.
« Reply #10 on: July 22, 2016, 03:51:50 PM »
That is what I was thinking
« Reply #11 on: July 22, 2016, 08:17:24 PM »
the bottom item looks like it could be used to stop the flow on small rubber or plastic tubing .while  making parts or inline filter change ????
with the sliding bottom, it would be easy to attach.
« Reply #12 on: July 22, 2016, 09:04:18 PM »
Hello, The hole diameter with the chuck tightened is 3/8" . The  hole in the handle is just shy of the full length of the handle. Thanks, Lou
« Reply #13 on: July 22, 2016, 09:16:41 PM »
Hello, I dug out an old catalog, Hammacher  Schlemmer & Co. , and it shows a piano tuning hammer with a Patent Date of October 3rd, 1899. Patent number 634016, looks similar to the one I have here. Thanks again, Lou
