Author Topic: Diamalloy Pliers  (Read 1450 times)
Diamalloy Pliers
« on: July 23, 2016, 02:06:10 PM »
Hello, I found this tool today, but I am at a loss once again to find another to compare to. It is stamped DIAMALLOY DULUTH U.S.A. L R 58 with the horseshoe  / diamond stamp. I am going to call this a Brake  Key Pliers. Is the LR for lock ring? Regards, Lou
Re: Diamalloy Pliers
« Reply #1 on: July 23, 2016, 02:30:13 PM »
I've most often seen it as a tool for removing lock rings from differentials; no reason it wouldn't work on certain types of brakes, too.
« Reply #2 on: July 23, 2016, 07:33:35 PM »
I usually use them on transmissions for the bearing snap rings.
I have used them to spread the clips on emergency brake levers.
