Author Topic: Old Craftsman Pulley? What's it for?  (Read 2516 times)
Offline swervncarz
« on: August 04, 2016, 07:23:15 AM »
 I'm assuming some sort of pulley but what would it go with?
Offline swervncarz
Re: Old Craftsman Pulley? What's it for?
« Reply #1 on: August 04, 2016, 07:24:52 AM »
I forgot to add that it is 14" long... Numbers on back are 018242
« Reply #2 on: August 04, 2016, 08:03:51 AM »
Looks like you could put a grinding wheel, or maybe a buffing wheel on the one end.
Offline Nasutushenri
  • Bussum, The Netherlands
« Reply #3 on: August 04, 2016, 09:20:22 AM »
That's right. It's called a bench grinder mandrel, or a saw arbor heavy duty shaft with 2 pillow blocks
Henri
Do not mind my bad English.
Flickr: https://www.flickr.com/photos/100761653@N07/
Offline swervncarz
« Reply #4 on: August 04, 2016, 12:37:25 PM »
Thank you
Offline leg17
« Reply #5 on: August 04, 2016, 03:49:40 PM »
Henri
Yup, you could put a saw blade on it and cut your fingers off.
Or, you could put a wire wheel on it and pick wires out of your hide.
Or, you could put a grinding wheel on it and hope the exploding pieces don't break a bone in your face.
All kinds of options.
Actually, it really is a simple pillow block arrangement with a grinding wheel adapter.
Your imagination is the only limit.
« Reply #6 on: August 28, 2016, 01:34:46 PM »
Similar to those are still sold for carving glass with a v shaped grinding wheel  and for other cold working. Lapidaries and gold/silver smithing buffing lathes are similar.
« Reply #7 on: September 14, 2016, 04:08:22 AM »
I would use it for a jack shaft on my mini bike project.
