Author Topic: unknown opener  (Read 2378 times)
unknown opener
« on: August 22, 2016, 03:08:57 PM »
 Can one of you widely experienced oldsters or one of you knowledgeable younger folks tell me what this was for.
 Closing the handle advances the rack approx 1/4 inch No markings.
Re: unknown opener
« Reply #1 on: August 22, 2016, 03:22:20 PM »
Can you adjust the placement of the slide?  I'm wondering if it's a jar opener: adjust the slide to fit the lid, clamp closed, turn.  We have a similar device with an open frame that's been handy at times.
Not sure what the two prongs on the other side are.  I'd speculate that the prong on the end was probably originally vertical to the body of the tool, like the prong on the slide.  What that did, though, not sure.  Maybe clearing out nostrils for people with severe head colds.
« Last Edit: August 22, 2016, 04:07:21 PM by Bill Houghton »
Re: unknown opener
« Reply #2 on: August 22, 2016, 04:18:11 PM »
                                      yes the placement of the slide is adjustable. I think I've seen one of these before but can't recall usage if I ever knew it.  Would have limited usage as nut cracker.
Re: unknown opener
« Reply #3 on: August 22, 2016, 05:40:19 PM »
Looks like a combination can opener and a jar wrench. One side is a can opener using the point. The other side looks like it would grip a jar lid.
Re: unknown opener
« Reply #4 on: August 22, 2016, 09:01:36 PM »
Tool For Removing Screw Caps From Jars, patent #736,455
http://www.datamp.org/patents/displayPatent.php?number=736455&typeCode=0
Earliest ones had a cast iron handle, then later they went to a pressed steel handle like yours has.
Re: unknown opener
« Reply #5 on: August 22, 2016, 09:13:04 PM »
 perhaps the point is used to lift the lid after removing the canning jar band.
 if the lid is sealed properly, you have to pry it to break the vacuum.
Re: unknown opener
« Reply #6 on: August 23, 2016, 09:11:34 AM »
Well the patent is the jar opener and DATAMP description cites a known example with can opener.  My question is why the shape and apparent slot at the non handle end of the jar opener?
I have an Edlund jar opener and use it often.  Like this one...
Re: unknown opener
« Reply #7 on: August 23, 2016, 10:43:36 AM »
 Thanks for the info. I tagged it with that patent and hung it with my jar openers.
Re: unknown opener
« Reply #8 on: August 23, 2016, 11:41:29 AM »
I have one of the Edlund types and use it often.
Offline mvwcnews
Re: unknown opener
« Reply #9 on: August 25, 2016, 10:52:46 PM »
The can opener works by stabbing the point into the middle of the top, and working the cutter around the edge of the can to cut the top out -- a repeated "stab. slide forward. stab".. with the cutter blade.  Without slicing your fingers during the process.
Offline mvwcnews
Re: unknown opener
« Reply #10 on: August 25, 2016, 10:58:17 PM »
EDLUND TOP-OFF in in DATAMP as well  ( http://www.datamp.org/patents/displayPatent.php?number=1894556&typeCode=0 ) -- the gearing only works to screw tops off,  unlike most jar wrenches that can be used to loosen & tighten lids.
The present category count shows 112 jar wrench patents in DATAMP.
