Author Topic: Flea Market Oddities  (Read 1668 times)
Online lptools
« on: October 17, 2016, 06:46:49 PM »
Hello, The piece at top is approx. 13" long, and the part that I am going to call the handle appears to be cast aluminum, or a pot metal. The blades? are steel, good cutting edges, one rounded, the other at a 90 degree angle. No markings, well made, blade assembly look to be replaceable. The piece at bottom is cast aluminum or pot metal, clamp mounts to bench. Pin? spike? rotates 360 degrees in the base, at the approx. angle shown, or can be locked in to vertical. Well made, no markings, had to buy it for the Mickey Mouse wing nut!!!!!!!! Regards, Lou
Re: Flea Market Oddities
« Reply #1 on: October 17, 2016, 07:56:34 PM »
I would say the one with the blades is some type of scraper.   The other one, well I put one in my sisters beauty salon.   The spike goes up into a foam head form, for wig styling.  I bet it could be adapted to something in a shop though.
Online lptools
« Reply #2 on: October 17, 2016, 08:26:43 PM »
Hello, Thanks. I never thought of that one!!. Regards, Lou
Online lptools
« Reply #3 on: October 17, 2016, 08:38:30 PM »
Hello, John K. Thanks for giving me the info. I found an ebay item that matches , item number 361709732290. Thanks again, Lou
