Clamp?
Started by lptools, November 27, 2016, 05:14:26 PM
lptools
Hello, The tool is stamped Sunnen Products Co. St. Louis , MO. Any insight as to what this would be used for? Appears to be some type of cam locking clamp. Overall length in the closed position is 12-3/4". The smallest opening (with the cam lever down to the handle) is 3/4", and the largest is 3-1/4", with 4 other settings between. Thanks, Lou
Northwoods
I am wondering about that unexpected bend on the end near the handle.
lptools
Hello, Northwoods. It looks original, no sign of damage, if that is what you are wondering. Thanks, Lou
turnnut
#3
 if I recall right, Sunnen made a lot of automobile rebuilding tools.
could it be to hold a piston to assemble the rod ???   NOPE !  just checked.
VALVE SPRING COMPRESSOR, patent # 1,720,802    Dec. 18, 1926
Lostmind
That's a complicated valve spring compressor compared to the one handed plier types.
I don't think they sold a lot off those. First I've seen.
Thanks for the post
amecks
From DATAMP:
"Marked SUNNEN PRODUCTS CO. - ST. LOUIS, MO - PAT. PEND. This spring compressor was advertised in the April 1927 "Chilton Catalog and Directory". It fit springs on several six-cylinder engines, and came with a set of six clips to hold the compressed springs."
Lou, you probably didn't find the 6 clips with the tool?
lptools
Hello Guys. Thanks for the info. No clips, what you see is what I got. Thanks again, Lou
