Author Topic: Flea market finds  (Read 2738 times)
Flea market finds
« on: December 11, 2016, 11:43:19 AM »
"Hello, The piece at top with the wood handle is unmarked, overall length is 18". The fluted piece appears to be solid steel, 1-3/4" tall, and tapers from the top 2" to 1-5/8" at the bottom.Vendor thought it may be cooking related? I know what the black painted piece is, just putting it out there. The top has a flat spring, and the wire rod moves upward, away from the bottom. In raised figures on the handle B & H, and PAT. 6-14-21 . I looked at a similar tool , but it had a later patent date around 1937. Regards, Lou
Re: Flea market finds
« Reply #1 on: December 11, 2016, 12:51:40 PM »
Bottom one is a meat tenderizer, I believe.
« Reply #2 on: December 11, 2016, 01:05:04 PM »
Hello, Papaw. That is correct!!! The patent number that I found for this style meat tenderizer is 2098856A, granted on November 11th 1937. The handle on the one in the photo is marked 6-14-21, but I couldn't find the connection for that date. Any guesses on the other item?  Thanks, Lou
« Reply #3 on: December 11, 2016, 03:20:25 PM »
The other item looks like one of those things you dip into a batter, then into hot oil to make pastry shells. The ones I have seen before the fluted end piece would unscrew so you could put different shaped pieces on. They were also aluminum.
« Reply #4 on: December 11, 2016, 07:55:41 PM »
Hello, Lewill2. Thanks for the quick reply. The fluted piece is steel, and appears to be fixed to the bent rod. I will research a little more with your lead. Thanks again, Lou
« Reply #5 on: December 11, 2016, 08:19:55 PM »
 I think that Lewil was referring to rosette pastry molds where they have diff. shapes.
 the one that LPTOOLS is showing looks like perhaps you would wrap the dough around the fluted end
 and heat it to make the shell.  with the wooden handle, you would be able to handle it if heated.
 ???  deep fried dough shells ????
« Reply #6 on: December 11, 2016, 08:31:51 PM »
Hello, I found one on the web. Here is the name that they are using .   "Traditional Kuih Pie Tee (Top Hat Mini Tart) Shell Mold".   I am not normally in the pastry tool section at the flea. There was a table where the items were $2.00 each, or 3 for $5.00. I needed one more item to round things out!!!! Thanks again, Lou
« Reply #7 on: December 12, 2016, 09:13:18 AM »
Now you need to find out if there's a pastry baking forum on which people are clamoring for that particular design.
« Reply #8 on: December 12, 2016, 09:53:23 PM »
Wouldn't surprise me one bit!
« Reply #9 on: December 13, 2016, 09:29:43 AM »
check one of these;
http://www.kooksonline.org
collectingclubs.com
« Reply #10 on: December 13, 2016, 08:01:46 PM »
I will admit I like to eat, and used to use these for fancy stuff.   The shells made great cups for goodies,  dust them with powdered sugar, pour in something containing strawberry jam,  after awhile you can pack on the pounds just sniffing them.
