Author Topic: bit brace socket  (Read 2246 times)
bit brace socket
« on: February 17, 2017, 04:04:14 PM »
I've had bit brace sockets but none with this diamond shaped projection on the side . It(the projection) is 1/8 in thick and 3/8 deep and 5/16 wide where it meets the body. Socket is 5/8 hexagon. I first thought this projection was casting flash but it is a definite cast projection. Ever seen this before or know usage of this projection ?
Re: bit brace socket
« Reply #1 on: February 17, 2017, 08:48:04 PM »
AS we wait for the experts, will venture it was a type of depth stop?
« Reply #2 on: February 17, 2017, 08:50:14 PM »
Hand held reamer/countersink?????
« Reply #3 on: February 17, 2017, 09:36:04 PM »
I have had a lot of those over the years, and I have never had one like that.
« Reply #4 on: February 17, 2017, 09:55:23 PM »
I can't help but think that is a user modification. Are you positive that piece is not gas welded onto it?
« Reply #5 on: February 18, 2017, 09:10:49 AM »
??? was it put on to remove dirt around the nut on an implement ???
I'm sure some of you had scraped dirt/rust with a screw driver to get a wrench or socket to fit a nut.
 just my 2 cent thought, Frank
« Reply #6 on: February 18, 2017, 10:35:09 AM »
 Tang follows parting line and appears to have cast surface. No evidence of welding
« Reply #7 on: February 18, 2017, 12:10:14 PM »
Interesting
Thanks for the better shot. In the other photos it almost looks like its gas welded.
« Reply #8 on: February 18, 2017, 12:15:14 PM »
Looking at these shots closer it appears that a fair chunk of that appendage is missing in action.
Offline rustyfordgarage
« Reply #9 on: February 28, 2017, 03:23:11 PM »
The two I have seem to be unfinished castings as well
Offline bird
  • Resident Rambler
« Reply #10 on: March 09, 2017, 01:58:53 PM »
I've had two that look like that one.... of course, goodness knows where they are right now.  But, if I have two, I'm guessing that it may not be a user modification??
Silent bidder extraordinaire!
