Author Topic: Can anyone tell me what these little wrenches are called?  (Read 2186 times)
Offline Mac53
« on: October 05, 2017, 11:59:12 AM »
Can anyone tell me what type of wrench these are, or what to search to find more of them? Pencil for scale.
-Marcus-
Re: Can anyone tell me what these little wrenches are called?
« Reply #1 on: October 05, 2017, 12:45:08 PM »
Stamped steel? Possibly  bicycle, or motorcycle??
Offline Mac53
« Reply #2 on: October 05, 2017, 01:22:08 PM »
Yes, fairly simple stamped steel. Pretty small, size similar to ignition wrenches, but I can't find anything similar under that name. I have one other that has a large end and a small end, as well.
-Marcus-
« Reply #3 on: October 05, 2017, 02:37:25 PM »
I've seen similar router collet wrenches, not sure if I have seen that type with a hole in the handle. Regards, Lou
« Reply #4 on: October 05, 2017, 03:17:48 PM »
Don't know the name, but probably part of an auto, bicycle, or motorcycle "set."  The hole in the middle was probably for a bolt that held the set together.  Such sets came in more substantial forged steel versions; I have one of the more substantial versions in my "gee, these are interesting wrenches" box.  I'm not a wrench gatherer, like many folks here are, so the box isn't very large; and it's pretty well buried behind/below other tools, so I can't easily pull it out for a show and tell.
« Reply #5 on: October 05, 2017, 04:59:18 PM »
I am not sure what those were for, but I have several sets of small wrenches that are not ignition wrenches. Ronson made a set , as did others, like Morgan Mechanix.
« Reply #6 on: October 05, 2017, 05:06:51 PM »
Hello, Papaw. I hope that you are doing better, and get home soon!!! So, what would be the letter designation on those? An OEA? Just kidding, I have never seen those before with the open end, and the alligator jaw. Take care, Lou
« Reply #7 on: October 05, 2017, 06:44:28 PM »
I guess OEA would be correct, though no one ever used that !
I am doing OK. Waiting for one more test before I get sprung from here.
« Reply #8 on: October 05, 2017, 07:56:26 PM »
  they look like radio repair wrenches, the open/alligator wrenches.
« Reply #9 on: October 05, 2017, 08:47:56 PM »
Indestro made a sorta similar wrench is sets for auto tool kits. Unfortunately I don't recognize yours.
If you do a search for stamped steel kit wrenches you may have some luck.
« Last Edit: October 05, 2017, 09:16:09 PM by bill300d »
Offline toolmiser
« Reply #10 on: October 06, 2017, 04:27:40 PM »
I have a "dremel" rotary tool, that is from 1977, and it uses a wrench shaped like that to tighten the collet.  I would have to measure it to make sure.
Offline Mac53
« Reply #11 on: October 06, 2017, 07:11:33 PM »
Thank you a lot everyone! You'll all probably hate what I do with these things though... I turn them into rings. Mostly I use standard ignition wrenches that are common, but these just look a lot cooler. I try not to wreck anything with much collector value, as I appreciate the tools just for what they are as well. Now and then a larger wrench falls victim to my hammer though...
-Marcus-
« Reply #12 on: October 07, 2017, 10:56:45 AM »
Those sramped wrenches were included with lots of products. A good example is bifold closet doors, for adjusting the swiiel hinge height.
I got one with a set of 3" wheels I purchased from Lowes lat weekend. I added them to my jointer to move it around.
Because they were and are supplied so commonly, I think it would be hard to identify specifically. Unless someone recognizes a certain one.
