Author Topic: Bronze or Phospor Bronze Lathe Centre ? ID Help Needed  (Read 4377 times)
Online rustyric
« on: October 16, 2017, 11:06:17 AM »
This is a recent car boot sale purchase. I believe it's lathe centre of some sort and I think its made of bronze or phospor bronze. I can't find any manufactures name on it anywhere. Is it a lathe centre and if so for what machine ?
Re: Bronze or Phospor Bronze Lathe Centre ? ID Help Needed
« Reply #1 on: October 16, 2017, 11:10:22 AM »
looks like part of a ratchet drill. I am at work, but have a couple home. I will look later, Lou
Offline toolman
« Reply #2 on: October 18, 2017, 03:32:12 PM »
Hello: I really do not think it is a lathe dead center. I worked as both an auto machinist, and job shop machinist in my younger days, and all centers, be they live or dead, were made from tool steel. Now, the other thing that stands out, is no morse taper, to fit a lathe tail stock. If it was a dead center that was chucked up, why this acme thread looking part, and or spring looking piece toward the end? I wish i knew what you have here, but come up empty, especially when you mention the soft material it is made from. Not much help to you, but Good Luck!
« Reply #3 on: October 18, 2017, 09:00:05 PM »
Im thinking it might be a valve stem from an old faucet or valve.
« Last Edit: October 18, 2017, 09:15:01 PM by bill300d »
« Reply #4 on: October 19, 2017, 03:49:46 PM »
Hello, Bill. You may be on to something. Rustyric; Are the threads left or right hand? Regards, Lou
Offline leg17
« Reply #5 on: October 20, 2017, 09:52:23 AM »
Picture shows right hand.
Valve stem seems likely.
« Reply #6 on: October 20, 2017, 11:26:10 AM »
 Maybe I'm seeing things wrong but if it is a valve stem ,which it does look like, when you turn the handle clockwise that would lift the stem up away from the seat which is backwards to the way a normal valve works?????
Offline kwoswalt99
« Reply #7 on: October 20, 2017, 12:27:21 PM »
No, turning it CW would close it.
« Reply #8 on: October 21, 2017, 05:27:07 AM »
I'm liking the valve stem suggestion also. And bronze would be the correct material for such an application.
« Reply #9 on: October 21, 2017, 05:06:06 PM »
Aren't hot & cold opposite threads? Old style tub faucet with 2 handles? Both turn downward toward the center of the tub to stop the waterflow, so one is turning clockwise, while the other is turning counter-clockwise?
« Last Edit: October 29, 2017, 05:48:36 PM by lptools »
Offline kwoswalt99
« Reply #10 on: October 21, 2017, 06:18:23 PM »
Aren't hot & cold opposite threads? Old style tub faucet with 2 handles? Both turn downward toward the center of the tub to stop the wate rflow, so one is turning clockwise, while the other is turning counter-clockwise?
Yes.
Offline leg17
« Reply #11 on: October 21, 2017, 06:36:05 PM »
There are tons of valves other than household faucets.
Online rustyric
« Reply #12 on: October 23, 2017, 03:01:18 PM »
Wow a valve ! For a tap (as i would call it here in the uk) I never thought of that.
« Reply #13 on: October 23, 2017, 11:32:27 PM »
A tap in the U.S. would have cold beer coming out of it.
XXXXXX
Online rustyric
« Reply #14 on: October 24, 2017, 04:54:21 AM »
A tap in the U.K. will have delicious room temperature ale coming from it, (you have to practice liking it), I'm still trying after 40 years of "practice"
